I was thinking of popping over and having a look as am in CHC tomorow night thru wednesday....
But I'm after:
RF - Indicator Cover
Rubber Boot from where Clutch lever goes into bell housing.
Door switches (ie the ones that turn the interior light on) x 2
Front Grill
Power Steering fluid reservoir (maybe, mine has a leak, but I may have fixed it)
I'm sure theirs other stuff, was gonna have a look and see what I might want
The front of my car has been hit so theres all sorts of stuff up that end that needs work or replacement.
Oh yea, the box is in, only toubles so far are two oil leaks, when hot, so there must be some bolts not quite done up enough, and alot of noise in 5th, but will test it out on the drive up tommorow. Otherwise, its sweet as bro.... oh and their isnt a breather hose on this box, and the tubes been cut
have to get one of those screw in ones
