WTB 4.875 ratio Terrano/Navara Front diff
As I have just fitted my last spare front diff, I'm in need of another (just in case)
Would prefer in or near Auckland as freight would be killer.
Side note;
39 tooth ring gear with 8 tooth pinion.
Thanks.
Side note;
Thanks.
Re: WTB 4.875 ratio Terrano/Navara Front diff
Bump
Bumpty bump!
I have now destroyed my last front diff.
I will spread the drag net further. i will travel or get ORE courier to deliver.
Any D21 Terrano or Navara, CA48 or HG48 diff will do.
sibainmud wrote:Bumpty bump!
must be time to tone down the right foot?
Time for a Safari. You could try this guy he had a stack of Terranos, He is near CHCH tho.
http://www.trademe.co.nz/Members/Listin ... er=1630732
What part of the diff have you destroyed? I've got front diff parts, but only a crownwheel in 4.8 ration (no pinion)
Crown wheel and pinion need to be a set.
Damn you must be giving those things a hard time.
Good to know the gearbox is standing up to the punishment
slide wrote:What part of the diff have you destroyed? I've got front diff parts, but only a crownwheel in 4.8 ration (no pinion)
I'll take that crown wheel. They ideally need to be a matched set but i know I have three pinions still installed in their housings. (Same pinion for most ratios)
I seem to blow teeth off the crown, right foot has a lot to do with it
As I know when they go bang, first thing is to disconnect the hubs and take it out of 4wd so minimal damage occurs to the pinon gear
I'm sure i can build a good one from the bits. i will need to pull out the bearing blue and spend a bit of time shimming
I can arrange some $$ for shipping.
I'll find it amongst my parts stacks, and dig it out this weekend. Send me a pm?
PM sent.
Thanks for that Greg. I don't have US$450 in the budget at the mo
Worth a thought though.....stronger bigger faster
lexlux wrote:https://www.4x4parts.com/nissan/drive-train-ring-pinion-sets-c-165_400.html
does this help
did you try dad mate man ur tough on those diffs my 4.6 have been sweet
TD power wrote:did you try dad mate man ur tough on those diffs my 4.6 have been sweet
Will give em a call in the morning. Last time we spoke about it you thought they didn't have any 4.8's.
Thanks for that Steve.
was talking to dad today he thinks he does
Gotta be cheaper than the rip off merchant in Kelston....quoted $450.....f#$&'n burglar
Here's the question I posted on the auction;
Hi There, Would you have a front diff (4.875:1 ratio) (HG48 or CA48). If so how much? Cheers, Simon. 11:28 pm, Tue 31 Jan
$450 7:11 pm, Wed 1 Feb
You must be joking!!!! Last one I got a few years ago from the most expensive 4X4 wrecker, only cost me $300. I have bought matched pairs of diffs for $100 for both front and rear. I have a perfect 4.6 ratio here (more common and popular) do you want to swap. I have done business with you before and even recommended you to others in my 4X4 club. Won't be doing that again! 9:58 pm, Wed 1 Feb
Basstard
Basstard
Man you have to take it easy, what happend to I need to take it easy before the 24Hr Endurance Challenge
Drurban wrote:Man you have to take it easy, what happend to I need to take it easy before the 24Hr Endurance Challenge![]()
I was
Sketchy_Racer
Hey man, just a thought usually stripping teeth off crown wheels is due to the housing flexing under load and reducing tooth contact area. It will be detrimental if you had a fulltime 4x4 and doing mileage but given that you might only cover a few thousand kms off road a year it shouldn't be a problem. When you rebuild the diff, put much more preload on the side bearings to help stop the crown gear moving away from the pinion gear under load if you know what I mean. (Rock crawler guys usually do it)
Sketchy_Racer wrote:Hey man, just a thought usually stripping teeth off crown wheels is due to the housing flexing under load and reducing tooth contact area. It will be detrimental if you had a fulltime 4x4 and doing mileage but given that you might only cover a few thousand kms off road a year it shouldn't be a problem. When you rebuild the diff, put much more preload on the side bearings to help stop the crown gear moving away from the pinion gear under load if you know what I mean. (Rock crawler guys usually do it)
That's my exact thoughts too. More mesh (don't care about a bit of noise), more preload on the main bearings. As I have been swapping out whole assemblies, they come from the factory set up like that. The last one was from a later model (95) wide body too.
Thanks for the suggestion Glen.
None there ether
Still searching.
Bumpty bump bump (happened to be the noise it made too
I'm still looking. If nothing turns up, I will have to fit a pair of 4.625's before Wednesday next week
It will suck having to remove the rear air-locker and put in a tight LSD
Surely some knows of a farked old Navara sitting somewhere in the upper north island
Bump
Could do with another spare one of these (killed another 2
Bump. Need one sooner or later.
Anything considered
Anything considered
Iv'e got one you can have for $450
kbjj wrote:Iv'e got one you can have for $450
I suppose that is PLUS shipping...
Considered.......ah.......no
BUMP
Have a wild guess what I did today
On the look out. Looking nation wide with the help of ORE Courier, of course.
Will consder terrano, navara or any year of D21.
- workin on it
- Driver/Navigator
i hav a 4.8 front diff laying around im in blenheim tho
workin on it wrote:i hav a 4.8 front diff laying around im in blenheim tho
How much? Need ASAP!
Can put post on courier service and see if can be picked up. Have club member coming north from Chch next weekend.
sibainmud wrote:BUMP
Have a wild guess what I did today![]()
Just buy a patrol & you won't have to do this ever again!!!
