for those of you who have an 80 series or are thinking of buying one, you need to be aware of an issue with the passengers side steering arm
I have had this happen to me and I heard Sig had the same issue and then this morning a fulla turned up to work for an alignment coz he said his wheels were pointing the wrong way, but the alignment wasn't the issue.
The left hand steering arm knuckle thingy has a habit of coming loose after time. the problem with this is that you dont really get any warning until theres only 1 of the 4 bolts left and the steering gets very sloppy. the bolts will either fall out or snap off, like this case and also the same thing happened with mine. I only had 1 bolt remaining and it was halfway out, 1 other bolt had fallen out and the last 2 had snapped off
I have taken pics of the offending item for your visual reference and I hope that you are vigilant in looking at these nuts on a regular basis as I would hate to see it come loose on the open road......
