TD27 EGR pipe wanted to borrow
For all topics relating to Petrol engines and modificiations.
fullthrottle
Shuttle Queen
Post by fullthrottle »
Hi
Anyone got a spare EGR pipe that I can borrow? The one that transfers exhaust gas back into the inlet.
Wanted to get a couple of plates made up to block it off.
Dirtydog
Re: TD27 EGR pipe wanted to borrow
Post by Dirtydog »
just put a peice of paper over the parts ya want to blank off, and rub pencil over it to get a template if ya cant fint one.
fullthrottle
Shuttle Queen
I wanted to borrow one so I could do that without taking the truck off the road.
slide
Post by slide »
I can probably trace around some and post up here with sizes to make sure that scaling is correct. Will have to find the time during weekend tho if you can wait that long
northdude
Post by northdude »
or get the gasket for it and use that for a template i just make a plate up out of panel steel when i do them
sibainmud
Post by sibainmud »
northdude wrote:or get the gasket for it and use that for a template i just make a plate up out of panel steel when i do them
That's what I did. Works treat. Then you can cut the pipe out from behind the head, much faster.
fullthrottle
Shuttle Queen
Good idea guys.
I'll go with that plan. Looks like a right bitch to get out otherwise.
northdude
Post by northdude »
cant remember how the td ones operate but if its got a vacume activator you can also just take the vacume tube off it and put a screw in to block the vac line off
slide
Post by slide »
Same size blank at either end. MAY be different after the valve located on inlet manifold, but the pipe its-self has this pattern on both ends.
Comes up on my screen as approx double its actual size (76mm long, 45 wide) I haven't resized it at all (trimmed excess off from scan is all), so I'm hoping if its reprinted it'll come out to scale. I'm outa ink so I can't check.
northdude
Post by northdude »
you only need to put 1 plate in either end will work
DEATH_INC
Post by DEATH_INC »
slide wrote:Same size blank at either end. MAY be different after the valve located on inlet manifold, but the pipe its-self has this pattern on both ends.
Cheers for that, can anyone confirm whether the intake manifold fitting is the same?
sibainmud
Post by sibainmud »
DEATH_INC wrote:Cheers for that, can anyone confirm whether the intake manifold fitting is the same?
Yeah, they're the same. Last ones I made were 1 alloy for intake and a steel one for exhaust. I now have both manifolds down in garage so will be making some more in next week or so. Perhaps I was a bit pedantic doing an alloy and a steel blanking plates but at that time I was worried about the gaskets giving up due to different expansion rates of different materials.
I'll let yous know if it is different.
slide
Post by slide »
Just double checked, both blanks ARE the same size.
sibainmud wrote:Perhaps I was a bit pedantic doing an alloy and a steel blanking plates but at that time I was worried about the gaskets giving up due to different expansion rates of different materials.
Yep, probably pedantic..
But I did this too.. :lol: ..
Steel would be fine on intake, alloy maybe not so good on exhaust.
If anyone making a blank up, make the exhaust one out of thick enough steel to thread and fit EGR probe
kiwipete
Post by kiwipete »
If someone is making some plates, can I order a set too please. :wink:
Ph 0212078472
