Can you help?
Can you help?
Ok so I need to know the name of the bar that bolts to the back of the rear axle to the body..
I need to get a adjustable one as my axle is 15 mm over to the drivers side after the new +2" springs were put in....
OR can you cut the factory item and make it adjustable? IE weld and fit adjuster
Re: Can you help?
Panhard? if it is you can make a drop bracket or make it longer I cut mine in half and used a bigger bit of pipe over it, doesn't have to be adjustable.
Re: Can you help?
nismo26 wrote:Panhard? if it is you can make a drop bracket or make it longer I cut mine in half and used a bigger bit of pipe over it, doesn't have to be adjustable.
Yea I thought is was called the pan hard rod but appco looked at me side ways...
So cut it and weld it? just make sure I get the right length first?
- ArvinSlayer
Re: Can you help?
grab a manual, if i am not wrong ures is a WD21 isnt it? Then u will know exactly what it is, i will see if i can scan my haynes manual page and pt it on later
Peace
Arvin
Peace
Arvin
Re: Can you help?
Where are you?
Re: Can you help?
they are called panhards but ive heard people call them track bars and all sorts of funny names.
theres some good ones on 4wdbits.co.nz which are adjustable, great for if you lift/drop the vehicle etc.
but i think making the mount lower on the chassis would be alot better because it keeps the rod more parallel to the axle.
Re: Can you help?
Panhard or panard.
The closer to horizontal at static ride height the better. The bigger the angle the worse the handling at speed.
Re: Can you help?
Rumour has it you can use a Toyota 80 series panhard in it's place...You may be able to source an adjustable and just change the bushes.
Would be worth looking into!
Re: Can you help?
Back when I was at Autolign we modded an adjustable commodore one to suit a surf.
Re: Can you help?
4WDbits wrote:Panhard or panard.
So might pay to lower the mounting point on the body?
Re: Can you help?
BogBoy wrote:4WDbits wrote:Panhard or panard.
yes if you can.
commonly done in the surfs.
the more angle you have the more the axle gets pushed sideways when the suspension moves up/down.
- passengerpete
Re: Can you help?
tom did this too mine. very well priced and what a difference.
Re: Can you help?
passengerpete wrote:tom did this too mine. very well priced and what a difference.
That's a pretty serious looking bracket, as usual from Tom.
I did the usual bolt in drop box that goes inside on mine, with a brace to the other side...but yup, I was surprised how much difference it made.
Re: Can you help?
Can he make another one? Weld on or bolt on?
