will post a before and after shot when i finish.....
here is the proposed section to take out, from the green tape to the ruler. This was justified by the corrogations in the well floor ending(if i go any further back will be a bitch to join again) and the front from where the body starts to curve into the wheel arches. And of course the spring hangers.... losing about 270mm all up.
the first cut.. no going back now
heres the second cut done.. would be sick to have been able to end body here .... but not until the cart springs dissapear
here is the final length mocked up..
still plenty of tidying up to do.... so far i have welded the back in place, cut and moved the rear body mounts forward and docked the chassis to suit..... will finish it off this weekend and post up the final shot..
conan.
