Hi all,
I'm wondering if any one had problems getting a WOF with spring spacer's on front and rear.
It's only 30mm raise in rear and 15mm raise in front.
This will be added in addition to the FTS 2" lift spring and shocks.
Whats the storie with going for a WOF with spring spacers???
Re: Whats the storie with going for a WOF with spring spacer
It all depends on you WOF man...
I had spacers on my truck once and he failed me... They were 1.5 inches long and were alloy...
Made so they located nice and snug...
Ended up with custom springs with a few coil bound turns to simulate the spacer...
If they're eurethane or rubber, try telling him they are isolators, not spacers. But as far as I know (not at work...) they are ok, we've fitted the 14mm ones plenty of times.
butcherboy
- Bush Crasher
ive got them in and had no problems mine are the ones from bits 4 vits
Ive got 30mm spacers in the front of my gu, no problem with wofs.
- Chairmen
Oh sweet thanks guys,
After hearing the mostly positive feedback i rekon it"l be fine, and if all else fails ill leave a full box of beers in the back seat with note "To inspector please enjoy"
