Campott wrote:And the transmission part...
Auto trans, d21 1992 td27.
Plenty fluid, looks ok in color.
Trans is getting warm on a regular basis. revs out to about 3000 between 1/2 and seems to really slam into 2nd.
Doesnt like to hold 4th for longer than 5 seconds no matter what the revs (goes straight from 3rd to 5th).
Auto change switch was replaced by a mechanic a while back as he smashed it replacing top fuel pump seals.. Could this be an issue?
Is my trans just buggered? Is it fairly easy to put a new one in? Worth the hassle to go to manual if I'm changing anyway? And what are recond. ones like from a wrecker-risky?
There should not be a 5th unless it has different than usual trans (could be wrong), they are re4r01a trans which is a 4 speed, 1/2/3(o/d off) then 4th...If "HOLD" button is activated they will take off in 2nd then shift straight to 4th, is this what is happening?...
If the part he smashed is the potentiometer (throttle position sensor) on diesel pump then yes that will be causing problems and explain why it wont chop down and hold gears when under heavy throttle, i am going through similar problems with mine at moment. He may have replaced it with new item but they need to re calibrated after removal and installation.. PM me if you want manual showing ho to do this.
The potentiometer sends a signal to transmission control showing how much throttle is applied..More throttle the longer it will rev gears, less throttle early shifts.
Mine since day one before and after rebuild hits hard into 2nd under heavy acceleration they can apparently adjust line pressure to help this, it has not caused any damage to mine though. Also as suggested get a large trans oil cooler and install right up front with good air flow.
And to same you last questions. I def would not go changing trans, silly little problem like the potentiometer is enough to convince people the trans is buggered and it is only a small little issue, easily fixed. Changing the trans is a prick of a job, it is very straight forward though, count up to a full day of heavy work unless you have correct equipment. Torsion bars ect will all need to be removed and reset after also, then wheel alignment set again.
