Fraser's 97 Wrangler
Re: Fraser's 97 Wrangler
Hey Fraser,
Your truck is not dirty enough, anyway looking good mate the mods are coming along good.
phraza
Cheers!
Cleaned some more of the Jeep today. Had the day off work. Took all the carpet out and gave it a vacuum. So much sand! Got most of it, but gave up in the end haha. Also took the door off for the first time and tried on my half doors that i got when i first got the Jeep over a year ago! They look awesome and can't wait for summer to take the roof off. Everyone likes pics:
Carpet out:
Door off:
Half door on:
Carpet out:
Door off:
Half door on:
2WD 06 Hilux... for now
Looks good. Any more details or photos of the half doors? Assume they are aftermarket or home built? How does the latch work? (scored some damaged full size doors which I was thinking of cutting down...)
Thanks.
Thanks.
what colour is yours and where are you. my half doors are red and wouldnt mind a set of full doors
NZJeep wrote:Looks good. Any more details or photos of the half doors? Assume they are aftermarket or home built? How does the latch work? (scored some damaged full size doors which I was thinking of cutting down...)
Thanks.
russty wrote:what colour is yours and where are you. my half doors are red and wouldnt mind a set of full doorsNZJeep wrote:Looks good. Any more details or photos of the half doors? Assume they are aftermarket or home built? How does the latch work? (scored some damaged full size doors which I was thinking of cutting down...)
Thanks.
Doors are silver and the frames are fairly twisted (came from a rolled '06) plus I only have the bare doors, no glass, latches or seals, etc. Only really good as scrap or to cut down.
phraza
Thanks.
Pretty sure they are aftermarket. When i bought the Jeep over a year ago from a dealer in Palmy, Greg on here (WRNGLR) had the half doors at his place cause he knew the previous owner. They are just wood (i think haha), and same colour and even the same silver pin-stripe down the side. Here is a couple of pics of the latches. No idea where they are from sorry.
phraza
Also got to figure out a way to turn off the interior lights when i use these doors. they don't press that button when you close the full doors to turn the interior lights off. Need to think of something to fit on the switch thingy
Thanks for the photos of the latch - look like standard slam latches. As for the door light switch, not sure if it would work with your half doors on but you can get a spring which holds the button in when the doors are off - i.e http://www.jeep4x4center.com/no-doors-l ... ee001.html
phraza
NZJeep wrote:Thanks for the photos of the latch - look like standard slam latches. As for the door light switch, not sure if it would work with your half doors on but you can get a spring which holds the button in when the doors are off - i.e http://www.jeep4x4center.com/no-doors-l ... ee001.html
Ah thats quite clever isnt it. I need to make something like that. Cheers! Might have a hunt around in the garage for something!
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
Eat, Sleep, Jeep...
phraza
00falcon wrote:http://www.stu-offroad.com/electrical/elec11/domelight.htm
Cheers man, might go down that road. A switch would be handy
Here is the spring, easy, cheap and reliable. You can get them from Greg.
Cheers.
Cheers.
phraza
Coljag wrote:Here is the spring, easy, cheap and reliable. You can get them from Greg.
Cheers.
Oh even easier haha. Might get them from him next time i order something
thanks!
sliders look good on the jeep.Also like the colour coded hardtop. I have the cheap import crappy chrome ones that rust out. next project may be to make a set with a step cause the kids are complaning its to hard to get in and out of the back
phraza
russty wrote:sliders look good on the jeep.Also like the colour coded hardtop. I have the cheap import crappy chrome ones that rust out. next project may be to make a set with a step cause the kids are complaning its to hard to get in and out of the back
Cheers man, pretty happy with the look of the Jeep now. Not sure what is next! haha
When i bought the Jeep the dealer said the previous owner told him the Jeep was some sort of special edition (colour coded hardtop and flares and with pinstripe). I have no idea, tried googling it but couldnt see anything. Was probably lies
phraza wrote:When i bought the Jeep the dealer said the previous owner told him the Jeep was some sort of special edition (colour coded hardtop and flares and with pinstripe). I have no idea, tried googling it but couldnt see anything. Was probably lies
You have a 'Sport' don't you...?
I understood the 'Sahara's' to have a few cosmetic extras like Color Matched Guards...
Did you email Chrysler about your build sheet...?
Did that give any indication about specifics to your wagon...
O[][][][][][][]O
Eat, Sleep, Jeep...
Eat, Sleep, Jeep...
phraza
00falcon wrote:You have a 'Sport' don't you...?
Yea mine is a sport, i got the build sheet. Couldn't really see anything on there that said it was different to normal sports. Might have another look
When I had my TJ (with canvas roof and half doors (factory)) I just removed the fuse for the light, then with your dash dimmer you can rotate it right down and turn the interior light on and off manually.
phraza
CLUMZ1 wrote:When I had my TJ (with canvas roof and half doors (factory)) I just removed the fuse for the light, then with your dash dimmer you can rotate it right down and turn the interior light on and off manually.
Yea i thought about that, i will only probably have my half doors on a few times this summer, so thinking a switch or that spring thing
Yip , doors are after market, Brett (2 owners ago ) made them himself, fiberglass over ply I believe, Phraza, could your light switch problem be fixed by a small piece of angled aluminium screwed to inside of door that closes on the switch like a normal door would ??? I haven't looked at mine lately to see. Also still have some bits and pieces here for yours, centre caps for original wheels, indicator stalk, and off mine a complete soft top Bow frame, I bought all the spare stuff for yours off the previous owner so I could get my hands on the bikini top, wind jammer rear window and deck cover, best money I ever spent.
Greg
Greg
phraza
WRNGLR wrote:Yip , doors are after market, Brett (2 owners ago ) made them himself, fiberglass over ply I believe, Phraza, could your light switch problem be fixed by a small piece of angled aluminium screwed to inside of door that closes on the switch like a normal door would ??? I haven't looked at mine lately to see. Also still have some bits and pieces here for yours, centre caps for original wheels, indicator stalk, and off mine a complete soft top Bow frame, I bought all the spare stuff for yours off the previous owner so I could get my hands on the bikini top, wind jammer rear window and deck cover, best money I ever spent.
Greg
Ah thats another good idea for the interior lights. That could work too! Ah yea, i sold the original rims it came with, don't think i need an indicator stalk though? haha.
Was thinking about a tummy tuck for my Jeep. Have you done one Greg?
phraza wrote:Was thinking about a tummy tuck for my Jeep.
Have you got a body lift...?
i thought you were spring only...?
O[][][][][][][]O
Eat, Sleep, Jeep...
Eat, Sleep, Jeep...
phraza wrote:WRNGLR wrote:Yip , doors are after market, Brett (2 owners ago ) made them himself, fiberglass over ply I believe, Phraza, could your light switch problem be fixed by a small piece of angled aluminium screwed to inside of door that closes on the switch like a normal door would ??? I haven't looked at mine lately to see. Also still have some bits and pieces here for yours, centre caps for original wheels, indicator stalk, and off mine a complete soft top Bow frame, I bought all the spare stuff for yours off the previous owner so I could get my hands on the bikini top, wind jammer rear window and deck cover, best money I ever spent.
Greg
Na haven't done a tummy yet , have the new belly pan for one tho, just have to move the bolt holes for the transfer case mounts, it's set up for an auto box, so the holes are back further. It's on the neva neva list with heaps of other shit
phraza
Yea im still thinking about it, i don't have a body lift. And i was reading the forums in the states and they said a body lift is a must. Might just add it to my long list of mods i want to do as well
