Could this be something to do with the way the LSD in the rear locks up?
May have to start doing the trips in reverse instead
tow99 wrote:which speedway cars might they be?
rangimotors wrote:U sure its not because your rear end has much better flex than your front so both wheels stay on the ground and get much better bite with less slip.
fullthrottle wrote:I've noticed that I can climb hills in reverse, much better than going forwards. Was having a play with it today and sure enough, every time a much better result in reverse.
tow99 wrote:the only cars that dont have gears are sprint cars thats why they require a push start and can't go slow .modifieds etc run al sorts of gearboxes.cf bed ford landcruiser hq etc.most of the time they will take off/cruise in one gear and race in another
