Hi guys, I have a customer with a 2010 Patriot who wants to do a little 4x4 driving. His daily rims are 20" so not all that good for tracks. Anyone know of suitable offroad rims for a Patriot? I have tried a couple of my suppliers and coming up dead ends.
He still has his original 17" rims but I am not sure if they are rated for offroad but that size has also a limited range for mud tyres. Keen to drop to 16" at least if we can.
W
Patriot offroad wheels
- williamhamilton
Re: Patriot offroad wheels
The MK's have a 5 on 4.5" (114mm) hole pattern and 39mm (1.535") of offset on the 16X6.5 rims which = approx 5.25" Backspacing. See chart and more info here: https://www.rsracing.com/tech-wheel.html
apparently the front calipers are often an issue on these (Patriouts) without a spacer.
I understand MKs have the same 5 on 4.5in stud pattern as YJ, TJ, XJ and ZJ. Wheels for these are common in 16 in variety. However, the issue you have to worry about backspace and clearance for the calipers, as well as guard clearance. Try a tyre off a TJ with 16 inch rims and see how it goes.
TJ Sahara / Renegade came with 16 inch rims from factory, mine was.
i'd be wondering why anyone would want to take a patriot off road???
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
- williamhamilton
phraza wrote:Show us a pic when its done
When he is done with his first trip or just when we find rim/tyre combo?
One maybe more interesting than the other
W
phraza
williamhamilton wrote:phraza wrote:Show us a pic when its done
W
haha true... either or!
2WD 06 Hilux... for now
- skid
- Tyre Man
NZ distributors are now doing 17" steel spoke wheels dude
http://Www.4wdbits.co.nz, where I got my 16 inch alloy wheels from. Why go steel and add un sprung weight on top of the tyres. Braking will not be the same.
just incase you slam down onto a rock and bend the rim.
much easier to fix a steel rim if ya need to out in the field, alloy rims just crack.
also cheaper to fix a steel rim if they become buckled.
Not all alloys crack. Depends on their construction method. The myth about steel rims being more off road friendly has been busted. I will not debate the issue here. Also alloys can be repaired, just as steel rims.
i suppose steel is a bit hevier, and only really comes in 2 sizes (commanly)
theyre cheap too though.
