Terrano key broken. how to get new one cut??
For all Nissan related topics
u13turbo
Post by u13turbo »
Ive heard you can get a number off the drivers door lock? i took the panel off and had a quick look without removing the whole lock but cant see any number. Is there any other way??
T-Boon
Re: Terrano key broken. how to get new one cut??
Post by T-Boon »
Nissan may be able to tell you ?
To Boon or not to Boon.
falcon5nz
Post by falcon5nz »
You'll have to pull the lock. Its engraved on it. Mine is now written on the inside of the door after getting sick of pulling it.
u13turbo
Post by u13turbo »
Sweet guys cheers. i just done some googling and luckily came accross a post saying it is engraved.
lownslow
Post by lownslow »
I just got a key cut today for my new pajero, the guy just looked up the model and year on his computer for the base key them typed some number after looking at the key put it in some fancy machine and was done. I couldn't see what numbers he was reading off the original key so no idea how he did it, was like he was reading the profile.
Have taken a barrel into them before too
Dirtydog
Post by Dirtydog »
the numbers refer to what tension the springs have i think, or something along those lines anyway.
i just make sure i have a spare key in the first place so they can copy it when it breaks.
Kimbo
Post by Kimbo »
The number you want is on the [b]Drivers[b] side door barrel only. There is a 5 digit number but you only need the last 4 numbers and on a terrano it is on the little metal tailbar on the back of the lock. If you have both parts of the broken key then just take them to a decent locksmith and they will sort it for you. And get a spare while you are there. :)
snork
Post by snork »
A good locksmith can decode the worn key and cut a 'brand new' key. However that doesnt mean it will work perfectly as the barrels would probarly be worn as well.
And yes , 9 times out of 10, the key code is on drivers side.
Return to “Nissan”
