Bypass shocks OR Coilovers?
brakes-shocks-lockers-etc
shortylux
Post by shortylux »
Im (slowly) building a winch challenge truck that should get used for some class 6 off road racing as well. Speed is more of a focus than articulation.
Looking for some advice/opinions on which would be more beneficial out of bypass shocks or coil overs. I cant afford both. It is a safari chassis with standard suspension. I will be running about 4" of spring lift and drop boxes.
The way I see it the advantages of a coil over would be that I could adjust my ride height for different applications, and that I would be able to tune my spring rate more accurately by buying different springs.
The advantages of a bypass shock would be that I could easily (externally) tune the dampening of my shocks, and also run a progressive feel in the dampening.
Any input appreciated, especially that from people who run one or both types of shock.
So, what do you reckon?
QUADRACER
Re: Bypass shocks OR Coilovers?
Post by QUADRACER »
By pass shocks are easy to adjust, rebound and compression.
4WDbits
Post by 4WDbits »
Go with the coil overs.
Articulation and off road racing are almost at opposite ends of the setup scale for springs. Articulation = soft, off road racing = firm to hard.
Shocks can be setup pretty firm for off road racing, and firm shocks it won't make that much difference when going relatively slow at a winch challenge.
There is almost an infinite number of combinations of springs for ride height and spring rate with a coil over. There is usually only a few choices for stock replacement springs.
shortylux
Post by shortylux »
Yeah that makes a bit of sense Warren. And I guess it's easier to add bypass if I already have coil overs, where it would be harder to add coilovers if I had it set up with bypass and standard springs.
DEATH_INC
Post by DEATH_INC »
4WDbits wrote:Go with the coil overs.
The thing they do have in common is you want lotsa travel. This'll be much easier to achieve with stacked springs on coilovers.
I'd run a stiffish shock like 4wd bits sez, and a soft and a hard spring (dual rate) to give a good rate on landing from jumps, and allow plenty of extension/sag, which gives both grip on the track and articulation when you're crawling without too much dive. Hopefully.
