wanted: ln130 drivers cv
scott-tauranga
Post by scott-tauranga »
Hi there I'm after a inner and an outer cv for a ln130 surf. Drivers side. Not wanting to buy new as it's only going to happen again, preferably in the bay but anywhere as long as you're willing to send.
sg8380
Re: wanted: ln130 drivers cv
Post by sg8380 »
hey there id say that you would be better of to get a new one, if it keeps breaking id say your putting it in wrong
1989 Surf ln130 2lt
31 maxxis buckshots
2 inch suspension lift
bob_or_jim
Post by bob_or_jim »
Buy "Genuine Toyota" ones mate, I used to be the same forever changing them. The toyota ones are alot better than the cheap "Repco" type ones. Also I found it was the bouncing that killed mine so I didnt let it get to that stage.
Problem stopped right about the same time the SAS happened, funny that.
UBZ
Post by UBZ »
sg8380 wrote:hey there id say that you would be better of to get a new one, if it keeps breaking id say your putting it in wrong
don't watse your money on new ones!
surf CVs are a dime a dozen . drivers / passengers side are the same .
If you get the front suspension in the right place you don't need to pull the diff or remove the spindle to fit them .
As soon as the front gets off the ground you hve to get off the gas or the CV or diff will let go when the spinning wheel hits the ground .
Interesting that you broke the drivers side . all the ones I blew we're the the passenger side . when you hve it out have a good look at the stub axle on the diff and ensure the bearing hasn't let go .
skidmark
Post by skidmark »
Have some in Hamilton, let me know if your interested.
tallsam66
Post by tallsam66 »
New from toyota complete end to end around $220..dont waste time with 2nd hand.
Then put an locka in rear ..then yuoll never break em unless you drive like a twat.
scott-tauranga
Thanks for everyone's help, funny to see everyone has different opinions
Will head down to Toyota tomorrow to price them up otherwise will be getting a cheapy
bob_or_jim
Yeah that’s the best/worst bit about forums, just depends how passionately people like to push there point :)
Just had another thought......how lifted is your Surf? Its not the angle at full droop causing them to bust is it?
mike
Last minute Mike
Post by mike »
They are a dime a dozen and I wouldnt waste your money buying new either. The guys that do the SAS usually just hiff them away.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
tallsam66
Post by tallsam66 »
mike wrote:They are a dime a dozen and I wouldnt waste your money buying new either. The guys that do the SAS usually just hiff them away.
I sold mine ...got $80 each side....they still sell for good money
scott-tauranga
Just has wound up torsions and springs in the back. Is there anyway I can change the angle so is closer to factory angle? Spacers maybe?
bob_or_jim
Yeah depending on how far it's lifted you can put spacers on the front diff to lower it closer to factory in relation to the hubs.
Although this doesnt help if there breaking on the shaft and not the CV its self.
