As the title says chaps, My interior fan is now only working on full, anyone had this problem and what is the fix ??? save me pullin everything out straight away and end up finding it was something simple I haven't checked, happened about 1 day after engine bay water blasted if that helps
Greg
Interior fan only works on full
Re: Interior fan only works on full
If its anything like a Toyota one,, they use a coil resistor to change the fan speed for each setting... Sometimes the resistors fail...
Yep, exactly as Calvin says. Its supposed to be a simple fix on a Wrangler.
excellent, thanks guys, where to ta get one of them
is this what you need...?
http://www.amazon.com/Wrangler-99-04-Heater-Switch-Mopar/dp/B004TC6USQ/ref=sr_1_3?s=automotive&ie=UTF8&qid=1355957452&sr=1-3&keywords=tj+heater+resistor
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
Eat, Sleep, Jeep...
magic dude thanks heaps, will add it to the list
