Part time 4wd on 80 series
Ive brought a 80 that im slowly moding up for the bush,is it just a matter of putting on manual front hubs to make her part time 4wd?
Re: Part time 4wd on 80 series
can do then just run center diff lock on in 2wd.... or there are proper ways of doing it as well, PM Turoa he done a few....
badnuz wrote:can do then just run center diff lock on in 2wd.... or there are proper ways of doing it as well, PM Turoa he done a few....
Hey thanks,So do you mean center diff lock has to be on for it to work in 2wd?
Yep or all your drive will go to thew front.
Get a kit and do it properly. From the guys I have spoken to who done the 2wd conversion it is a bloody good mod, ie they love it.
Hi all and sorry (no I'm not
) to thread jump, what are you trying to achieve by part timing
is it saving wear and tear, economy or ------ ?. Grant can the 90# Prado's be changed to 2WD
not that I would bother I love the way mine hangs on to the road when pushed to the max
, shingle and wet roads have a lot of GO FAST car drivers EYES glued to the rear vision mirror
ONLY WHEN THE HAND BRAKE IS NOT THERE,
FITZY.
FITZY.
rokhound wrote:Yep or all your drive will go to thew front.
Marks 4WD Adapters do kits.
http://www.marks4wd.com/part-time-4wd-k ... rsion.html
SMOKEY wrote:Hi all and sorry (no I'm not) to thread jump, what are you trying to achieve by part timing
FITZY.
Hey fitzy. Not sure if there is a kit for the 90 series, but you can just put a kzn185 surf transfer case on and that will do the trick. Actually it should have been done at the factory as this gives the option of allwheel drive and part time. Not sure about free wheel hubs on it though......
petefj40 wrote:rokhound wrote:Yep or all your drive will go to thew front.
All good will go down this route
Cheers guys
Best you try and find someone in Melbourne and purcahse it there or you will be raped by the chch agent. I am pretty sure I got the last one for a mate for around $530 landed.
If you ring/email them, they will just put you to the closest agent. If you have an address that you can send them to in Aussie it saves all that BS.
They cost $585 oz dollars not sure how you can land them here for $530 nz?
You could 18mths ago
Still, go and talk to the chch agent and see how much he wants for them
http://www.offroadexpress.co.nz/Forums/ ... 22&t=31810
have a read of this before you go spending your money in oz .
