simex or silverstones..?
Big
Post by Big »
ok I need pro's and cons of both as simexs are dear enough and I dont want to fk it up.. :lol:
I have a screaming 8 :mrgreen: that loves the revs when giving it the fat..Basiclly It comes down to either of these 2 tahs..
Which would you recommend :?: and why :roll:
nztimr33
Re: simex or silverstones..?
Post by nztimr33 »
I have 35 simexs on my truck as a daily driver their noisey as #### of the road but awesome off road , ive heard the silverstones are a softer rubber and more susecptable to guard rub and rocks etc cutting them if i were u id go for the simexs , also there isnt much difference between the two price wise ? like 20-30$.
the silverstones were always an undersized tah, they have got new moulds bringing the size up now but from what I've been told you have to be carefull what you order coz theres still old undersized stock floating around
as far a comparison between silverstone and simex the silverstones have bigger voids between both the centre blocks and outside blocks and are a softer compound
Sadam_Husain wrote:the silverstones were always an undersized tah, they have got new moulds bringing the size up now but from what I've been told you have to be carefull what you order coz theres still old undersized stock floating around
what he said
if you decide to go for silverstones you need to get one's that have a manufacturing date later than February this year, then you will get the new one's that are supposedly 35.5" on a par with the Simex
sibainmud
Post by sibainmud »
It depends on your truck too. As said above, Silverstones have bigger voids so they don't need so much horsepower to spin them fast enough to clear. They suit lighter trucks also as the cases are a bit softer and bag easier.
But my choice would be Simex as they put up with much more punishment and wear slower.
My 2c worth.
Drurban
Post by Drurban »
You can not go wrong with either, both do much the same job I have nothing bad to say about the Simex or Silverstone's........... yeah I do they are bloody noisey on the road apart from that they are great, I have at set of undersize (non true) 33" Silverstones and I am very happy with them.
I also agree with what sibainmud said in above post.
juz
Post by juz »
Never had the Simexs but had the old Mongrels then Silverstones, I run them on the road a bit too and apart from noise there fine. although dont like ice! :shock: Road noise is about same as exhaust so just turn stereo up! :mrgreen: Im running 35s now and there $413 new, never found simexs under $500ech. Ull be able to run 35s fine.
muddyplumber
Spring Free
Post by muddyplumber »
Have ran 35 and 36 simexs,felt the 36" triple blocks didn't seem to clear the mud properly....iv heard that if you run big power best bet is the simex over the silverstones as they can have a tendency to tear lugs off...iv only ran dirty diesels so never had to worry bout the high hp issue :lol:
Rich
Big
Post by Big »
Thanks for the input guys :D .. didnt really help as I know what most were saying :lol: ... Would the new silverstones not be as prone to tearing off lugs.. :?: its my main reason to not get them.. as price for simexs is main reason not get them but if it means not tearing lugs then I'll get them.. see what I mean..I dont really want to spend 400 each only to fk them .. rather spend more and have them last.. :wink:
Big wrote:.. as price for simexs is main reason not get them but if it means not tearing lugs then I'll get them.. see what I mean..I dont really want to spend 400 each only to fk them .. rather spend more and have them last.. :wink:
when did you last price silverstones there not 400 bucks anymore there almost the price of simexes :shock: :x :?
juz
Post by juz »
http://tyreshoponline.co.nz/shop/catalogue/category-5.html
Thats there new prices, also on trademe for $430ech and resonably priced of Mud Hog (tigerz11) :D
oh and thats for 35/10.5R16 was 35/10.5R15s cheap new recently somewhere, must have been on special.
EDIT: found the dude on trademe.. $390 for 35/11.5R15
http://www.trademe.co.nz/motors/car-parts-accessories/wheels-tyres/tyres/auction-491788138.htm
Big
Post by Big »
http://www.4wdaccessories.co.nz/store/tyres/extreme-tyres :lol: :wink:
nows the time to buy then before they update the price lists :D
williamhamilton
Post by williamhamilton »
I still have a couple of 35" Silverstone sitting in the workshop check out http://www.offroadexpress.co.nz/Forums/ ... =5&t=30780
W
007
Post by 007 »
From what I have seen, I think both are a good off road tire, of the same design.
Sizing is another consideration, especially if you want the 36'sX12.5 which is an advantage of the Simex and size does matter.
But the larger lug spacings of the silverstone equals more grip in a comparison size, which is important if you are restricted to the smaller tire sizes.
Silverstones should also be easier to bag with the the softer compound.
It is a tough comparison as both are so similar.
You will also need to consider the weight of your rig and how often you plan on replacing them.
If you 4wd in Queenstown the rocky terrain may also be a consideration for you
They are both popular tires. I have never run silverstones but find the simexes (36X12.5) great in the goo.
ford ranger wildtract and sj.
Big
Post by Big »
007 wrote:From what I have seen, I think both are a good off road tire, of the same design.
Yip I hear ya, but the tahs will be solely for comp and mud runs as I have club tahs now which work great around here..and If i need more I just bolt on the chains.. :lol: so I guess either will do fine but my main concern was ripping lugs off and fking the silverstones...If the new ones are going to be able to handle the jandle then I'll most likely get some of those as they are cheaper if they are when I actually get some.. :? so it really depends on when I can at this stage..
ski
Post by ski »
I am in the same postion and not being able to decide, curently running silverstones 35 on my mid wheel base cruiser an wanting to up grade, Does the weight of 4wd come into it as I notice that alot of 4wd using silverstones are middle to lighter trucks?. Cheers.
Bulletproof
Post by Bulletproof »
If you intend to use them in Central Otago I wouldn't have either. They are a tractor tire that is self cleaning and not designed for spinning. The rock down there would destroy them in 2 seconds. My Simex are ripped from a 3 litre.
Go for a radial in that terrain would be my advice. I very rarely use my Simexs at Reefton because of stone in the ground. They are good at Westport though
Cheers Richard
Never say die, up man and try
Big
Post by Big »
Thnx Richard, I have a set of Big Horns for the river work and general running around but for when the need arises.. :mrgreen: like inter club comps and or winch comps etc I need something better.. and still really not sure what to get but foir the price and the fact that ill only be using for comps the silverstones maybe the winners at this stage beit still a way off.. :( , They will be looked after between events etc.. going to and home again.. just not sure which..lol
zephyrheaven
Post by zephyrheaven »
Federal couragia MT - great
00falcon
Post by 00falcon »
Guys,
TJ Wrangler
3" Lift
(1" Body and 1" Motor mount probably coming)
Stock Gearing 3.73:1
Looking at either
32" Simex @ 33.3" @ $430 each
Or
33" Silverstone @ 32.5" @ $350 each
(unsure if new size or old size yet)
Im after aggressive mud tires, as i will be keeping my current 31" ATs as my road tires.
The Simex or Silverstone will get some road use, as currently i don't have the ability to transport 5 tires, then change on site.
What would you recommend i get...?
Naturally the Silverstone's seam more attractive from a price point of view...
But money isn't everything...
O[][][][][][][]O
Eat, Sleep, Jeep...
www.nzjeepclub.co.nz
Big
Post by Big »
Well after getting the silverstones.. im totally happy with how they rock.. I just have to learn how to use them :lol: :lol:
I have noticed a move towards the silverstones but Im not sure weather its because of price of performance.. :?: and I have noticed the top guys starting to use them and cant fault them really..compared to the simex..
I had 1 run on them and can say they are awesome but cant really compare to anything else as I havnt had anything else.. if that makes sence..lol time will tell.. cheers
00falcon
Post by 00falcon »
Big wrote:Well after getting the silverstones.. im totally happy with how they rock.. I just have to learn how to use them :lol: :lol:
Hi Big,
Yeah, i think I'm leaning towards Silverstone's.
However, i am still in 2 minds about my mud tires.
My concern is that i do not have the ability to transport 4/5 tires, they will get some road use.
I understand these are not road tires, but how to they fair/ware on the hard stuff...
Bearing in mind, i will also be keeping my current ATs
O[][][][][][][]O
Eat, Sleep, Jeep...
juz
Post by juz »
They dont wear that quick, I got my 35" Silverstones off kbjj with I think 12mm tread? cant quite remember, but I use my truck to run around town a bit and weekend 4wd trips and dont change them. Ive probably done 8000km on them and they wouldnt be down to 10mm. On a heavier Vehicle, Safari 80series etc I imagine road kms would be alot less though.
00falcon
Post by 00falcon »
juz wrote:They dont wear that quick, I got my 35" Silverstones off kbjj with I think 12mm tread? cant quite remember, but I use my truck to run around town a bit and weekend 4wd trips and dont change them. Ive probably done 8000km on them and they wouldnt be down to 10mm. On a heavier Vehicle, Safari 80series etc I imagine road kms would be alot less though.
I've got a 1800 KG Wrangler...
So...
Perfect...?
O[][][][][][][]O
Eat, Sleep, Jeep...
Bulletproof
What you have to remember is that an off road tire is only good for the first half of the tread depth and then needs replacing so the ks you get if you use them on the road are quite low.
Cheers Richard
Gnarly Dude
Post by Gnarly Dude »
Got the silverstones on our Prado in 35's, pretty wandery and noisy on the road although that is to be expected. Real good off the road have saved us a big panel-beaters bill because slipping doesn't happen anymore, it's like having another set of lockers! :D Highly reccomended
datsunsafari
Post by datsunsafari »
been running 35 inch silverstones for around a year now offroad (have a set of 33s for daily drivin)very happy with these awsum grip in mud,mine are not balanced at all and drive fine on the road although noisy as hell but i can live with that.i run around 15psi offroad and 38 on road(driving to the tracks) :) oh and they are the 'new'moulds
Drurban
Post by Drurban »
I have recently got a set of 32" Simex's for my truck, I have not yet had a chance to try them out prior to that I had the 33" Silverstones which in my previous post said they are awesome Iam expecting to get the same result the only difference is size wise.
00falcon
Post by 00falcon »
I don't know about Silverstones vs Simex...
But i went with Silverstones.
Anyway, first run with them, and there is something to be said for "Mechanical Sympathy"
Compaired to my Dessert Duelers i didnt have to push half as hard.
previous hills where i had to 'give it death' to maybe make it up, and simply crawled up with ease today.
I like my new tires... :)
O[][][][][][][]O
Eat, Sleep, Jeep...
Return to “Tyres”
