wtb 60 series semi floating long rear axle
- tomsoffroad
- Flopsie
As above. It seems I've used my spare
Re: wtb 60 series semi floating long rear axle
Shouldn't this be in the parts section?
- skid
- Tyre Man
zukmeista wrote:Shouldn't this be in the parts section?
shouldn't you be in kindergarten
- Sadam_Husain
- Angry bird
williamhamilton had a complete 60 series diff he kept on tripping over that was for sale not so long ago, dunno if it was front or rear, SF or FF or if hes still got it?
No pictures?
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
- ClassicCruiserSpares
- Sausage Shack
I may have one lying around somewere, do you have any measurements dude?
Seen some pics on FB. Are those your pics Tom (or pics of the "fullfloater axle...floating"
taken by someone else )?
Driving it like ya stole it - Good on ya mate!!!
- mudlva
you would never believe what i took to scrappy two or so months back....
i may still have another rear diff thats s/f in the back if you get stuck as "freight at the going rate " mite kill it....
otherwise i could also put it on mainfreight i hear they arent to bad. might only be a GBH not a full out carnage
how urgent??
how urgent??
did you bent your diff in that flop over you had?that guy nxt to wrks one been sitting in paddock 3yrs i been their.If your not in hurry will ask when back at work?boss would let us use transporter truck to.
give me a yell if keen
pretty sure williams is a semi floater .he offered it to me but i need a full floater as well .
Sadam_Husain wrote:williamhamilton had a complete 60 series diff he kept on tripping over that was for sale not so long ago, dunno if it was front or rear, SF or FF or if hes still got it?
- tomsoffroad
- Flopsie
Cheers everyone. Just after an axle as a spare for the next mission. I have plans to build something a bit better soon, just run out of time
Next mission is a week away
- mudlva
tomsoffroad wrote:Cheers everyone. Just after an axle as a spare for the next mission. I have plans to build something a bit better soon, just run out of time![]()
does this imply that you are breaking them regularly??
- tomsoffroad
- Flopsie
mudlva wrote:tomsoffroad wrote:Cheers everyone. Just after an axle as a spare for the next mission. I have plans to build something a bit better soon, just run out of time![]()
I dont plan to break another one, but would feel a whole heap better if I had a spare on hand.
measure it dude, i may have one.
- tomsoffroad
- Flopsie
Right I had a measure up, which I hope is accurate enough cos the spline end is twisted off and doesnt line up anymore
I got 850mm from the inside of the hub flange to the end of the spline.
Thanks everyone
Thanks everyone
- mudlva
?? Hub flange or wheel stud plate??
Full floater has hub drive flange
Semi float has wheel stud plate
If you break s/f axle whole wheel and brake assembly leaves the case leaving you with just 3 wheels
If you break f/f axle it is the same as doing a cv engage locker and drive on the other side as wheel and brakes stay put
- tomsoffroad
- Flopsie
Ok.... wheel stud plate
Yes wheel, brake drum and axle walked out the housing
- mudlva
all good
sorry but i had to ask as atm i dont have eny spare f/f axles
i had a look out back and there is a s/f complete diff there just have to run a tape over it to confirm whether its a 60 or 70 diff
90% its a 60 but not often im right... so if you need it shout out and i will drag it out and do the measure thing
Rohan
Rohan
