martin
new2zukes wrote:hi all had a bit of a trouble with my nissan terrano manual gearbox today, it decided to let go of all the gears but 4th. it has stuffed out on me 4 times in the last 4 years now and I'm a little sick of it. was wondering if a nissan safari gearbox would fit into my truck with a little less worry that it will break down every year. i am getting quicker at taking the gearbox out now it only takes a day nowif anyone else could give me a little more info about the gearboxes that would be great thanks.
martin
lax2wlg wrote:Yeah Nissan released a service bulletin in the 90s, the original oil capacity leads to oil starvation and premature failure. If you fill it from the side it will only take 3.5 litres, but it MUST have 5.1 litres! Easiest is by removing gearstick.
Also Gearbox MUST run on GL4 fluid, which is far less common but still available. Apparently GL5 has additives and detergents which eat synchronizing rings and wear out bearings easily.
Dirtydog wrote:just swap it for an auto, sounds like way less hassle lol.
i dont know much about the manuals, but i know most nissan autos are interchangeable.
wax wrote:The gearbox is a non weak point. Put in a mistral manual gearbox its the bigger box.
Nissan has two gearboxes they use. There is the one they use behind 4 cylinder turbo engines and the ones they use behind the 6 cylinder turbo engines( not the rb20)
its non as the silvia box or the skyline box.
they also do this with the diesels. the terrano has the small box the d22 and the mistral have the big box. put that in and the job is done. There was one for sale on eBay in Australia for 150 dollars they are cheap. I also know of another ones coming up for sale in Australia but its not going to be cheap.
lax2wlg wrote:Hmmm I don't know much about the r50... Yep you are right on the dates, below is the link to the official tsb
http://www.wightman-crane.com/madkiwi/TSB97-009A.pdf
new2zukes wrote:lax2wlg wrote:Hmmm I don't know much about the r50... Yep you are right on the dates, below is the link to the official tsb
have spoken to the gearbox rebuilder and he pointed out that the gearbox in mention in that article is an fs5r30a and they only came out in the v6 engines, so that doesnt mean that the filler is in the wrong place in mine. please correct me if im wrong here but it sounds as if was just the v6s.
