D21 Navara SAS with falcon rear leaves
rokhound
Re: D21 Navara SAS with falcon rear leaves
Post by rokhound »
Good shit Jezza. I had a scamper that I tubbed and fitted 31" boots to in the late '90s. It is def the way to go for comfortable sleeping :wink: :P
kbjj
Post by kbjj »
Quick setup and packup, and light to tow for my we donk.
...and yes Taz, I have a passenger seat... I think... if I behave... see you there
ClassicCruiserSpares
kbjj wrote:...and yes Taz, I have a passenger seat... I think... if I behave... see you there
Lol behave? why would you want to do that :lol: Ill tow ya pop top for ya on the godley trip if ya like? :D
P.s trucks coming along nicely good work dude.
kbjj
Post by kbjj »
:D Could be a plan Jason. We will talk further
Right, how I plan on painting repairs etc,
1) PA10 all bare metal (well what I can get at),
2) then fisholine into all seams, sills, etc with a weed sprayer nozzle (bore holes where needed and bung later),
3) use panel glue to seal up all seams etc (whats best),
4) hippo line interior floor (because apparently its hard wearing),
5) under body seal where needed (allready have some) .
Any better products or sugestions?
Trench_rat
Post by Trench_rat »
My nav rotted in all the same spots , im a tradesman panelbeater and your pretty much on the money with your method but fish oil should be the last step otherwise the oilyness can stop paint from sticking and therfore allow rust to creep back in , oh and underseal is your best friend :D as for seam sealing any urethane based adhesive sealer will do (cheaper than panelbond) then drown everything in underseal and after its cured get your fishoil in every bolt hole/ alighnment hole / gap in the structure , just a question did you use a weld through primer on the insides of your patches? if not make sure you really hammer it wil fish oil or these will be the first bits to go. good luck cant wait to see it finished.
Trench_rat
forgot to mention that if you can afford buy some good quality cavity wax like tectyl instead of fish oil , it lasts longer gives better protection and wont leave your truck smelling like you picked up some hamilton girls last weekend :lol:
vvilly
Post by vvilly »
Trench_rat wrote:forgot to mention that if you can afford buy some good quality cavity wax like tectyl instead of fish oil , it lasts longer gives better protection and wont leave your truck smelling like you picked up some hamilton girls last weekend :lol:
If slu.ts were aeroplanes Rangiora would be a airport lol the Tron got nothing on Goon lol
kbjj
Post by kbjj »
Trench_rat wrote:My nav rotted in all the same spots , im a tradesman panelbeater and your pretty much on the money with your method but fish oil should be the last step otherwise the oilyness can stop paint from sticking and therfore allow rust to creep back in , oh and underseal is your best friend :D as for seam sealing any urethane based adhesive sealer will do (cheaper than panelbond) then drown everything in underseal and after its cured get your fishoil in every bolt hole/ alighnment hole / gap in the structure , just a question did you use a weld through primer on the insides of your patches? if not make sure you really hammer it wil fish oil or these will be the first bits to go. good luck cant wait to see it finished.
Cheers for that. Weld thru primer?? Is this simalar to purge welding. It's all been tig welded with stainless filler rod, so at least the welds will last :lol: and they look ok from the other side.
That tectyl sounded good, but I've got the fisholene now. The Underseal I've got is thick tar typ stuff. I'm going to need to fisholene before gluing/sealing so it gets into seams etc but will paint what I can first, yeah?
juz
Post by juz »
Cavity wax/fisholene is always the last thing to get done, If you seam seal everything then paint then cavity wax youll be fine, I mean its a 20yr old truck are you still going to have it in 20yrs? your repairs are probably better than the factory job anyway.
Trench_rat
haha your question's answerd mine , its basically a zinc rich primer that doesnt burn away around welds insted it sort of liquifies and then encapsulates the weld in areas that you cant easily access to prime after welding. fish oil has to be the last step otherwise it will also stop the sealer from adhering properly which will cause grief down the track. I wouldnt get too concerned really aslong as you underseal it to keep the moiusture out and use plenty of fisholene your repairs will last for years , just dont stick it on its lid again!
kbjj
Post by kbjj »
The POS is going again
kbjj
Post by kbjj »
Ford Mondeo fans mounted on there own frame that supports there weight. Glued rubber 'flare moulding' to shroud edge that sits against radiator core. Moved Radiator forward 40mm to give fans plenty of room, which ment losing air-con and bonnet latch, and cutting recess into bonnet brace etc etc
Welded ali fitting to manifold thingy so I could utilize standard air-con hose for on-board air. Drawing air off the top of the motor breather catch can
Napenape
juz
Post by juz »
good to see it up and running again! how you finding the jungle trekkers?
red-devil
Post by red-devil »
Nice fish you caurght O sorry that should have been nice truck :roll: :lol:
kbjj
Post by kbjj »
juz wrote:good to see it up and running again! how you finding the jungle trekkers?
A better all-rounder I think, early days yet thou. They are softer in the side walls compared to the silverstone Xtreemes , and I have popped them off the beads 2 or 3 times already.
Dirtydog
Post by Dirtydog »
still looking good, i am interested in what axle you used for the front ant transfercase setup etc?
i wish i sold the ranno and got a navara, but its yet to be certified so i may just chuck a navara cab on it yet. thinking maybe a d22 to be different :D
If your ever down this way id love to go on a mission with ya
keithal
Post by keithal »
Dirtydog wrote:still looking good, i am interested in what axle you used for the front ant transfercase setup etc?
kbjj wrote:Well, someones asked, so here goes.
Ummmm....
Front diff housing is hilux with the ends chopped off, tube welded on other side and GQ safari balls machined to fit, running a Prado high pinion head (4.8, shimmed with extra spring LSD), Bj60 axels, and GQ cv's, knuckels, hubs, brakes, etc.
Setting up bump stops accuratly, as needed a reference point for other mounts, positioning etc.
Dirtydog
Post by Dirtydog »
thats right, cheers for joggin the memory :oops:
kbjj
Post by kbjj »
suzolla
Post by suzolla »
Are the splines the same or did you respline the ends on the axles.
Tim
kbjj
Post by kbjj »
Tim
Same same, just plug and play. Good luck getting axel out of gq cv, I had to cut original axel off, dismantle, then machine the remaining axel out of birfield.
Jeremy
rokhound
Post by rokhound »
shit Jezza, what's wrong with the rh side doors in that pic above? :P :P
kbjj
Post by kbjj »
rokhound wrote:shit Jezza, what's wrong with the rh side doors in that pic above? :P :P
Minor prob, window winders go around ok but no glass appears. Just as well really, cos at least the boy can get in and out of his door that wont open, and I can reach the bungee that holds mine closed. Now I just need a bigger garage to put her in when not in use
rokhound
Post by rokhound »
Mr Bean it with a pad bolt and padlock. Tek screw some corrugated iron over the windows......... presto. All fixed :lol: :lol: :lol:
tomsoffroad
Flopsie
Post by tomsoffroad »
kbjj wrote:Image
So tell me a story............. Where'd you fellas end up? How was it? Is it a mission for the future? :mrgreen:
kbjj
Post by kbjj »
Went up to old Townshend hut site (simple farm track) and found a lovely wee camp site. Photos are from a couple of side tracks that may need a little further investigation with the right permission :twisted:
IcedJohnno
Trailer Trash
Post by IcedJohnno »
kbjj wrote:Went up to old Townshend hut site (simple farm track) and found a lovely wee camp site. Photos are from a couple of side tracks that may need a little further investigation with the right permission :twisted:
Tee Hee Hee!
kbjj
Post by kbjj »
vvilly helped source me some doors from Mt Thomas Rd wreckers, or 'horsenut' on tardme. Good bloke, cheep prices (Gavin that is) :lol:
Think I'll keep old doors for hard yaka trips :twisted:
niblik
Post by niblik »
kbjj wrote:Think I'll keep old doors for trips :twisted:
That's a mint idea.
kbjj
Post by kbjj »
Right... am in the process of fitting an elocker to the rear, was going to use a surf rear axel housing and do a disc conversion, but it ends up being a similar width as my std navara that I'm presently running 25mm spacers on. I would like to get rid of the spacers, and would like to know the width of a kzj rear diff, disc face to face. I already have the housing, and might try to source some axles and do a disc 'conversion' to loose the drum hand brake. The housing I have is 1350mm flange to flange.
Cheers in advance
Jeremy
