whats the cheapest way to do a 50mm lift on a safari swb
whats the cheapest way to do a 50mm lift on a safari swb as i am thinking of getting one
1989 Surf ln130 2lt
31 maxxis buckshots
2 inch suspension lift
31 maxxis buckshots
Re: whats the cheapest way to do a 50mm lift on a safari swb
Put a jack under it
NJV6 wrote:Put a jack under it
- Sadam_Husain
- Angry bird
Saf's are prone to cracking body mounts if you do a body lift and you'll have to throw 500 bucks at getting it certified if its a road legal truck so personaly I'd go down the road of a suspension lift which will probably work out dearer if you need to stick longer shocks in it as well, if its only a 2" sus lift chances are you'll keep gettings wofs as normal with the need to certify the longer springs
do you know what a cheap set of lift springs are and do you need new shocks for a 50mm lift?
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
dobi springs are around $100 a corner,your shocks should be ok for 50mm lift
ok, where do you get dobi springs for that price? and what is the biggest wheels you can put on with that?, thanks
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
bnt,autolign ect might pay to shop around to get the best price.33 inch tyres will fit
If you get lifted coils, IMO you might as well get shocks to suit. If you have factory units, you won't get the full benefit of running lifted coils.
- crazyclark31
get some standard front springs and shocks from an 80series. Then just get some spacers for the rears to suit. Your standard rears will work but not last long from constantly topping out. Have givin my lwb 50mm lift for total cost of $75. Isn't my prefered way but it works. Will do it properly when wife lets me
so if i got some standard 80 series springs and shocks for the front that would give me enough to get new shocks and springs for the back
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
sg8380 wrote:so if i got some standard 80 series springs and shocks for the front that would give me enough to get new shocks and springs for the back
Depends if its your daily driver, personally id save up and buy matching springs and shocks all round with spring rates designed for your vehicle.
You will end up doing it in the long run anyway. Aftermarket options for safaris are great and the ride on most of them is such an improvement on factory. I went tough dog on my gu and it hurt at the time, but It will last and driving it everyday Im glad I did its so plush. I put 80 series fronts in my prado bush truck, It was hard to get it level as they compensate for the 80s offset fuel tank and spare wheel so had to shuffle them around a bit works ok. On a plus, 80 series factory front shocks from waikato toyota only cost me 80 bucks each new.
Id get a set of lift springs designed for your truck and bar/winch if you have one first, then save for new shocks to match. See how it drives, and castor correction bushes as well if needed.
i have a set of 7 month old dobi springs 2'' lift for a SWB safari that are going on trade me this weekend, they are literally like new, still have the stickers on, they have done 2000 road kms and never been off the road. $300... i bought them new and took them out of a truck just before i sold it...they are going on tm this weekend though. in hamilton..
oh yeah i wont be buying them for a while, i might just save up for all new springs and shocks
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
- Sadam_Husain
- Angry bird
is the lift just to get bigger tyres to fit mate?
yeah kinda and i just like them raised
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
