Wanted - landcruiser steering shaft
Petemcc
Post by Petemcc »
I am after a steering shaft from a 70 series land cruiser or square shape prado. After the shaft that goes from the steering box up to the steering column. They are longer than the hilux ones and will work for changing to an IFS box on my LN106
PM or text/call
Pete
0274738362
Re: Wanted - landcruiser steering shaft
they are different length steering shafts Pete, the full size 70 series cruisers have the p/s box right up the front with a rear facing pitman arm and the prados have the p/s box mounted further back with a forward facing pitman arm
vvilly
Post by vvilly »
78 series collapsible shafts
Petemcc
Post by Petemcc »
Cheers for that. Hmmmm i thought they were all the same.
vvilly are you saying that the one i want is the 78 series collapsible shaft?
vvilly
Post by vvilly »
Petemcc wrote:Cheers for that. Hmmmm i thought they were all the same.
I'm pretty sure it is, that's what I used. Its got the 12-13mm female on one end and the same in male on the other.
You can cut the two shafts to length but not weld. I'M trying to remember the shaft end of the 130 steering column. If its the same size 12-13mm you use a 70 series steering uj
skidmark
Post by skidmark »
vvilly wrote:... I'M trying to remember the shaft end of the 130 steering column. If its the same size 12-13mm you use a 70 series steering uj
my vzn130 has male spline on one end(same as gq steering box...)and a plate on the other end to bolt up to the rubber doofer thing..can get a pic and measurments if helpful
Petemcc
Post by Petemcc »
So the bit I'm using is the upper section rather than the bit that goes down to the box?
a 78 series playdoh shaft should be a shorter version of this one
LH end is a 17mm U/J to go onto steering box shaft and RH end a 14mm spline on end of shaft to connect to U/J on steering collum
vvilly
Post by vvilly »
thats right the female is bigger :)
