HZJ73 Crusier info
Sawdoc
HZJ73 Crusier info
Post by Sawdoc »
Hi Guys, a question for you crusier guru's. how is the transfer case driven from the transmision on an auto HZJ73 with the 1HZ motor. Mine gave a small bang then lost drive today and need to know what may have happened.
Cheers in advance :(
91 HZJ73 Cruiser, 4.2 non turbo,33 x 12.5 kl71's,UHF radio, snorkle, diff breathers, Factory winch, Awesome club truck.
fourby
Re: HZJ73 Crusier info
Post by fourby »
did you lose just front axle drive or complete loss of drive?
Sawdoc
Post by Sawdoc »
Yep complete loss was wondering if is a chain type drive to transfer case or cog type :?:
kiwicruza
Post by kiwicruza »
Hi. Its gear driven. If you don't have a pto winch you might be able to remove that side cover and have a look at the transfer case input shaft/gear side of things. You might be able to see if transfer case input (=gearbox output) is spinning when the auto turns, which might narrow down if its the auto or transfer case (put it in 2wd and up on axle stands), but to fix anything the transfer case will need to be split anyway. If you are not comfortable pulling it down yourself and exploring for the problem I'd suggest getting it a mechanic - could be auto or transfer case issue. Cheers.
Sawdoc
Post by Sawdoc »
Thanks for the reply Kiwi. i have drop it to the workshop for the experts to deal with.
Cheers Tony
Return to “Toyota”
