The shed clean out continues
410
Front and rear axles with diffs
A motor and box (unknown condition, truck wasn't in a good shape when I got it so bear this in mind)
2 transfer cases
413
Complete rolling chassis (without wheels lol)
Has
4age motor and corrola 5 speed box
413 transfer case
standard front axle
Rear axle has subaru leone calipers with the hand brakes hooked up to separate hand brake levers.... yep road legal fiddles
standard springs with extended shackles
Galvanised front and rear bars and bolt on slidders
Also got a set of 4 15x7 crome rims that I've flipped the centers on... the fifth one is is a white spoke
Offering this up here before it hits trademe
Offers
027 541 8794
Suzuki bits 410 and 413
Re: Suzuki bits 410 and 413
Also got a set of 5 White spokes 15"x6"
$150
$150
Been asked for pics of the 15x7 flipped center rims
They were made for my lada trials truck, when I flipped the centers, I put a DTI on them to tolerance them to 0.75mm run out they have been used since then on a suzuki for a road and offroad use
They will need paint as they have a small amount of surface rust on the crome and bare welds on the area where I welded the centers
They also have had the valves moved in against one of the center spokes and drilled for tractor tubes
Price given the work involved to flip them $250 for the five rims
do you have any 410 driveshafts by any chance?
LR110 ..... LJ50 project
Will have a look tomorrow
how much for a kit to convert the 4age into another 413?
PM sent.
dvs43va@hotmail.com
- Stropper
have you got any front leaf springs with hangers?
would you possibly want to swap with cash your way the rear brake setup on the 413, does it use the sj rotors? i can trade sj calipers and mudbits disc brake brackets etc, i want road legal fiddles!
Sorry all gone
