imsohi wrote:2MEKE wrote:imsohi wrote:... was thinking 2ct from van
This is what I used.
I wouldn't do the conversion the reasons Phil mentioned in his first post though.
I built mine to use on the west coast of northland to get to my dive spot/go fishing and have fun.
Economical? ... yes in high range when cruising. Low range? ... not so much but 3rd/4th gear it has sooo much torque it's not funny (actually it's heaps of fun
Ok cool if you are talking about the hard riding yea i can understand that its one of my friends that is wanting to do it think he is also looking at coils at the same time. He will do all the work himself so save the dollars there. Did you use toyot manual box if so attached or the divorced transfer?? may go down the road of 2ct auto from van to suzuki divorsed transfer as an option, keen on other ideas tho
Not so much hard riding as soft riding. But like I said, it was built for a particular purpose which it serves well.
Mine is engine/bellhousing/clutch from a Liteace van, W56 and transfer, double carden shaft in the rear cause it's steep, custom front shaft, hilux diffs, liteace radiator, surf brake booster/master and a lot of custom made bits
Also converted it coils all round at the same time.
The Suzuki bits are a '97 hardtop cut down to a soft top ute (it was rolled) on an '87 chassis so not really a Suzuki at all.
