Is it easy to fit a spoiler to a surf?
hey i have a kzn130 surf that does not have a spoiler on it at the moment and i would like to put one on, is it hard to do and how do you do it?
Any help would be much appreciated
Thanks
Sam
Thanks
Sam
1989 Surf ln130 2lt
31 maxxis buckshots
2 inch suspension lift
31 maxxis buckshots
Re: Is it easy to fit a spoiler to a surf?
sg8380 wrote:hey i have a kzn130 surf that does not have a spoiler on it at the moment and i would like to put one on, is it hard to do and how do you do it?
Thanks
Sam
Assuming you are referring to a front spoiler, as soon as you go off road it will come off a hellva lot easier that it went on!
i think he means a rear spoiler that goes on the top of tailgate/rear of roof.
yeah i ment the rear spoiler with the tail light on it
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
sg8380 wrote:yeah i ment the rear spoiler with the tail light on it
Have you got a 4WD for off road or is it a race car?
Can't see the point in it for a 4WD, especially one that is intending to go off road. Gues its just something else for the trees and branches to wipe off.
Hi, why do want to put one on?
Reason I ask is I've just taken mine off because I hate how the spoilers look on surfs..
If you want to put one on, you'll need to drill four smaller holes in the back to hold it on, and one big one to fit the spoiler, the big ones for the wiring. All the wiring is revealed underneath the rear trim at the back/top of the boot area. Check to see if the wiring is there?
- KIWI_TERRANO
Ralfie wrote:sg8380 wrote:yeah i ment the rear spoiler with the tail light on it
No one mustnt understand what they look like
my surf had one way good helped prevent dust coming in rear window when down on 4wd trips
I believe they are easy to fit have had couple mates fit them up
hey i like the look of them and like he said the stop the dust coming in the back window and also reduce the exhaust fumes
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
are these the holes it screws into?
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
are these the holes on the othe4r side and are they the plugs for the light?
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
Yeap, that looks like them, you'll just have to drill them out once you get the spoiler. Everything else should come with the spoiler.
hey do you have one for sale by any chance as you took your one off?
1989 Surf ln130 2lt
31 maxxis buckshots
31 maxxis buckshots
sg8380 wrote:hey do you have one for sale by any chance as you took your one off?
Yes I do, its a green one. PM me.
I had one fitted to mine, was an easy job as everything is there plug wise as you have found.
I had a surf with one and bought another without, but had it fitted. They do make a difference with sucking the exhaust in with window down. Not as much difference as I had hoped but still noticeable. Personally think they look better too, esp on the pre '95 Surfs, the later ones with the rear view thing look a bit boxy and more likely to rip off. Mine ('94) has brushed off everything so far, but mine is a bit of a shiney!
- bob_or_jim
I have fitted one to and LN130 89 year and it was an ass to say the least. Im sure 93 onwards will have the provisions for them though. Deff helped with dust on the back window and exhaust with the window down. As for getting ripped off, unless you like to drive upside down in your truck I would say rather unlikely. From memory there only a little higher than the roof as there out the back more than up. Plus ide hate to see that state of your roof if thats a real issue for you
I've got a blue one for sale with all nuts bolts and loom PM if interested. Easy to fit.
