This one is in good condition
It has 280k on the original head (I think?)
My questions are:
1) How can I test if there is head damage without taking it to a mech?
2) The 4WD light only comes on when I push 4WD and Hub Lock buttons together. Ie. it won't light up when just 4WD is selected ?
3) There is a slight wurring noise comming from the rear at 40kph+. I think it might be the diff. What do you guys reckon ?
If I do get it, I was going to:
* put in a new alloy radiator or maybe just flush the factory one? (Done)
* fit a external trans cooler in series before the factory one (Done)
* remove EGR (Done)
* fit larger exhaust from turbo back (2.5") - autobend off shelf item ?
* fit genuine toyota thermostat (Done)
* service/repack viscous fan (Done)
* fit a EGT gauge from pre-turbo (Done)
* Intercooler ?
* Re-oil rear diff
* Chage electric hubs over to manual (Fixed electric hubs)
Thoughts on the above?
I've just sold the challenger and can't wait to get back into the landcruiser world!
Thanks in advance
Tim (chch)
