hilux/surf parts - gbox ifs diff Lseries extractors
Petemcc
Post by Petemcc »
Garage clean out. All parts are in Queenstown, pickup preferred. Make an offer. Going on trademe next week
L series extractors will fit 2l 3l and 5l motors. Came off a ln106 hilux and comes with front section of exhaust. Flexy joint is a bit buggered but still ok.
Aircon pump off a ln130 surf truck was mint condition. should be good. Will refund if its buggered.
4.5 ratio IFS diff rear diff was in mint condition never been off road or near water. I haven't seen cleaner diff oil. This one should be the same. Feels nice and tight
130 series surf bumpers front and rear. Rear is mint but no ends on it. front average
130 series surf running boards frames at the back are a bit rusty but no dents on the boards.
130 series surf rear sway bar
Bell housing out of a ln106 hilux 3l motor to G52
4 dunlop adventurers 205R16 5mm tread only two in pic because the rest were at the bottom of the pile.
ADD transfer case off a R151 130 series surf gearbox
R151 gear box and transfer was in my ln106. off a v6 surf but has L series bell housing. Will bolt up to 2L 3L and 5L motors has crossmember mount for ln106. Also has a spacer on the rear output shaft to fit in the ln106.
These are a nice big strong box. great condition nice through all gears up and down. only took it out to go dual transfers.
Not 4wd but also have this windsurfer gear. what you see is what you get. the board went walkabout a long time ago.
Pete
0274738362
Petemcc
Re: hilux/surf parts - gbox ifs diff Lseries extractors
Post by Petemcc »
Also have a red/grey left rear door of a ln130 good conditions includes glass and window motor etc. Will put a up pic later
Petemcc
Post by Petemcc »
Bump trademe on monday
Petemcc
Post by Petemcc »
bump.
firestonecruiser
Post by firestonecruiser »
how much for extractors
Petemcc
Post by Petemcc »
$165
Petemcc
Post by Petemcc »
bump on trademe now most of it pretty cheap. a few $1 reserves
http://www.trademe.co.nz/Members/Listings.aspx?member=307938
Pete
