VVILLY TONKA-KZN185
kbjj
Re: VVILLY TONKA-KZN185
Post by kbjj »
vvilly wrote:
kbjj wrote:Congratulations, only little steps but you've managed to drive 20 metres off the beaten track :lol: :mrgreen:
found a good fishing hole for ya so ya can get the bloody fly rod out
Fcuk the fly rod, nearly snapped it out of frustration the other day :evil: I have enough fun and success spin fishing.
We'll get that truck dirty yet. I went up the Garry on Thursday got stuck in wee mud hole and needed a wee winch Its very over grown, that'll brake in your paint :lol:
vvilly
Post by vvilly »
After doing this the other day i thought i might get a bash plate made up to stop my radiator trying to escape through my bonnet scoop.
she is up at Toms for him to work some magic:)
vvilly
Post by vvilly »
Brought new front rotars as old ones were skimmed and were at 17mm. So the new ones were drilled and Fitted. That stopped my braking wobble. Re packed my kingpins, that stopped my bump steer/death wobble. Had a great day as for progress on the truck today.
Got my hands on a new rubber panhard bush for the prado diff but it too big. So on the lookout for one. If anyone can help.
vvilly
Post by vvilly »
forgot to put up some pics of the bash plate tom made
vvilly
Post by vvilly »
Played around with the spare wheel carrier today. Will get it sand blasted and powdercoated once i have finished.
vvilly
Post by vvilly »
BlakeNZ
Post by BlakeNZ »
Good on you for building your dream truck.
What are the latest mods on the spare tire carrier for? The ones up top?
When you said you went with relays to control the auto trans, does this mean you changes gears manually with the lever, or is it somehow still fully auto?
vvilly
Post by vvilly »
BlakeNZ wrote:Good on you for building your dream truck.
The Spare wheel carrier it to carry ropes, Reverse spotlight mounts, and Antenna Base.
they Auto Computer Mod was the fact that the Auto Engage for the 130 Transfer case, and that the wiring diagram was different but it did pug together. So we got rid of the computer to engage it and ran three relays to engage/disengage the transfer case. the auto still ran of the 185 wiring diagram, sorry for confusion.
vvilly
Post by vvilly »
My Birthday pressie fitted
removed the ashtray and the bracket screwed straight into the existing holes that were there for ashtray no cutting or drilling required happy as
vvilly
Post by vvilly »
Double post
keithal
Post by keithal »
vvilly wrote:Image
im assuming your going to flip the display on the uhf?
having the numbers upside down would annoy the piss outta me (OCD kicking in lol)
vvilly
Post by vvilly »
keithal wrote:
vvilly wrote:Image
Yeah mate it is the flip one 80 channel, it is fitted the right way up.
:D :D :D
vvilly
Post by vvilly »
So when i cracked the radiator a few months ago i also bent my draglink. Not too bad but enough to get a new one.
Chatting with Tom i ended up getting one made through him.
Side by side big difference
reused the tie rods and re fitted new one
shouldnt bend this one :lol: :lol: :lol:
vvilly
Post by vvilly »
So this weekend was a busy one in the truck. Saturday Removed the transfer case bash plate because it was too close to the transfer case and was vibrating under load. What a mish after hitting the bolts with a grinder because the fuel tank was in the road. We finally got it out. Used a press and massaged the plate into a new shape :). Then had issues since we bent it a bit and the mount holes didn't quiet line up. Got it in, in the end. I'm glad I got a hoist on hand :). Thanks Rangiora Toyota haha. While I had it up there I gave her a oil transfusion. Sunday. Put LED bulbs in the dash. What a let down. Not happy. Also fitted tweeters to the top of the A piller internal plastic soldered them up to a 3.5 mm jack in mono form and plugged them into the UHF. Works mint as really happy.
mudbugga
Post by mudbugga »
What don't you like about the LED's in the dash Jase?
Too bright or not enough spill to properly light up everything?
vvilly
Post by vvilly »
mudbugga wrote:What don't you like about the LED's in the dash Jase?
The three main T10 wedges sit into a bit of perspex that reflects the light but it doesn't work properly i can see the odometer but can't see the speedo
ill go take a photo
vvilly
Post by vvilly »
this is the three T10's
Before
After
mudbugga
Post by mudbugga »
Yeah that sucks.
vvilly
Post by vvilly »
some new toys arrived in the post today new reverse lights
Out with the old in with the new
comparison
vvilly
Post by vvilly »
vvilly wrote:Image
now i want to mount these onto the top to brackets of my reat bar
question is i want to wire them up to run off my reverse lights as well as off a permanent switch, from inside the boot.
does anyone have a wiring diagram that i can use.
Mattman
Post by Mattman »
I wired in a single reverse lamp that is run off a three way switch. I don't have a diagram but hopefully this is clear.
Off, on, and auto. Auto is triggered by the reverse lights. The switch is a double throw with two LEDs to show what mode is selected. The switch has an earth to a light pole for the illumination LEDs.
The single reverse LED lamp only draws 3.2 amps so I don't use a relay to power it, the switch is rated to 15 amps so can handle the current. The switch has one input and two outputs selected depending on the rocker position. 10a fused 12v goes to the input pole.
One output pole goes straight to the led lamp for on mode. The other pole goes to a normally open relay that is triggered by the reverse lamps. One side of the relay coil is earthed and the other is fed from the reverse circuit. The supply comes from the switch to the relay and goes to the reverse LED.
Any questions let me know.
Matt.
vvilly
Post by vvilly »
how is this???
will this work
KIWI_TERRANO
Post by KIWI_TERRANO »
vvilly wrote:how is this???
will this work
Oh wait looks like my doodle haha
vvilly
Post by vvilly »
will this work
um..... your doodle??????
yes it looks like your drawing brad
Mattman
Post by Mattman »
As long as you don't try to use an illuminated switch as they expect one input and two outputs whereas you have two inputs and one output.
That's why I went with a relay so the illuminated switch would work. I couldn't find a dpdt illuminated switch so used a spdt one with a relay.
Matt.
vvilly
Post by vvilly »
Mattman wrote:As long as you don't try to use an illuminated switch as they expect one input and two outputs whereas you have two inputs and one output.
Matt.
show me your art skills Matt hahaha
KIWI_TERRANO
Matt.
3 way switchs have 2 inputs and 1 output as in picture? Thats just a standard toggle switch nothing fancy
And i think he mounting it by rear door so a switch with a light in ant all the important, shouldnt need relays for a set up like that
Mattman
Post by Mattman »
No one's going to see my doodle! Haha.
As above Kiwiterrano - this will work okay as long as you don't want to use a switch with illuminated LED's in it as the reversed current flow through the switch by using it with two inputs and one output means the LEDs won't light up on the switch.
If you are just using a simple no led switch then go for it.
Matt.
KIWI_TERRANO
Mattman wrote:No one's going to see my doodle! Haha.
Matt.
I love doodles though...
Jase loves them to im sure :) haha
mudbugga
Post by mudbugga »
Jase has his arms full of doodles ;)
