Thought it was about time I tried some off roading and 4x4 ownership.
Just got a MK1 pajero 1990 swb. Only just in the stages of cleaning her up, servicing etc before I decide on upgrades.
First time today on a bit of sand and I got it stuck and feel like a right idiot. Problem it appears is that 4wd won't engage. When in 4h or 4l the wheel lock light comes on and only the back wheels turn. Anyone tell me where I'm going wrong / what I did wrong?
Probably the first of many newbie questions as. I try this new hobby!!!
Newbie help
Re: Newbie help
Does it have front manual hubs?
Got any pics of your first stuck moment?
2WD 06 Hilux... for now
Re: Newbie help
Might be worth asking this question in the Mitsubishi sub forum also. - as Fraser said, check if you've got manual or auto hubs!
- Newbie
Re: Newbie help
It has auto hubs. I don't have any pics but some spectators do!! Super embarrassed
Re: Newbie help
does the front diff on these have a solinoid to engage the front diff? if so that might be buggered cause same thing happend with my mates surf
Re: Newbie help
oh years ago a newbie here managed to roll his truck first time out 20 metres into the track
, so your doing well
Re: Newbie help
what i try and do is figure out wher the problem lies 4wd not engageing will be any of three problems 1 transfer case not engageing 2 diff not engageing (prob wont apply to you with auto hubs) 3 hubs,axels or cvs broken
First i jack 1 front wheel and 1 rear wheel off the ground any ones to start with then turn rear wheel while watching drive shafts (in 4wd) both should spin if they do transfer is ok. Spin front wheel check axels are turning freely and driveshaft is spinning if axels not moving usually hubs if every thing is working i swap front wheels and try again, process of elimination
