Feb 15-17
Camel
Feb 15-17
Post by Camel »
Thursday : 14th Valantines day, so Gave my truck some loving .
Stripped all tyres of rims and got all the mud and sand out of the rims,
I was loosing too much air ( So much that I had a flat last weekend in woodhill ) ..
Noticed Rear brake pads have worn down heaps since last time I checked
Friday : Work was dead as , So up went the Safari on the hoist,
Fixed rear tail pipe that I ripped off a few weeks ago in the bush .
Made it sit up higher and finished behind the rear bar, so hopefully this lasts longer than factory, and previous quick fix :lol:
Started to replace rear brake pads, thought I'd meassure my ok looking discs, they were .6mm Below spec , and all my vents in the disc (Vented discs - Rear of Y60) coverd in sand and mud!.
So threw Away the Disc rotors, New Rotors and Pads
Removed the rear heat sheilds , should clear mud and sand better than before ( Have removed front heat sheilds when I did Diff seals and they do clear mud /sand much better than with them on.)
Flushed out all the brake and clutch fluid, Greased up the driveshafts .
Checked Bearings, wheel nuts , any leaks etc .. All is Ok ,
Ready for Wheeling in the Sand dunes tomorrow .
Sunday - Free tickets to the v8s at Hampton downs, will go for a lookie,
maybe I can pick me up a spare LS2 or LS3 / what ever they run in them touring cars . Would be a cool engine in the Safari :!:
Dirtydog
Re: Feb 15-17
Post by Dirtydog »
na dont get an ls2/3, get a vk56dett.........
lax2wlg
Re: Feb 15-17
Post by lax2wlg »
Started tearing this thing down today, will keep going till the adrenaline stops (4am to give my sister a lift to the airport). Hope to have it down to bare chassis by early Sunday w/ tons of good parts available
sibainmud
Re: Feb 15-17
Post by sibainmud »
lax2wlg wrote:Hope to have it down to bare chassis by early Sunday w/ tons of good parts available
Good to know. You don't have any R180 4.875's front lying around?
You'll see why below :P
Most productive day. Changed yet another front diff today. Takes an hour to remove one from the truck, but gravity is a big help :lol:
While there wasn't a diff in the way, replaced both inner cv boots as one was split and the other wasn't far behind.
Big thanks to Workin On It for the 4.8 diff I got picked up from Blenheim.
Tightened up a few loose steering and suspension parts too.
Pics :P
Filthy4x4
Re: Feb 15-17
Post by Filthy4x4 »
Well nothing exciting this weekend, it was supposed to be maintenance weekend :roll: :roll:
My gearbox decided it liked to crunch 3rd every change up or down, so I went out and grabbed some thicker oil and some lucas stop slip...
Drained the oil out, drain bung looked pretty much identical to the one above :lol:
3 small keys(?) fell out the bottom of the box which im guessing are something to do with the syncros :evil:
I will be keeping an eye out for a non dreamer priced pto gearbox to go in or I will look at getting it rebuilt... anyone got one?
All part of the game we play :mrgreen:
027 MUD GEAR - (027 683 4327)
Check our facebook:
andy3542
Re: Feb 15-17
Post by andy3542 »
Does this mean im allowed to come 4wding with you again :?: :D :lol:
Offroad Addiction TV
Filthy4x4
Re: Feb 15-17
Post by Filthy4x4 »
I was under the impression that was a lifetime ban? 8) 8) :lol:
Check our facebook:
sibainmud
Re: Feb 15-17
Post by sibainmud »
andy3542 wrote:Does this mean im allowed to come 4wding with you again :?: :D :lol:
When you get your truck going :lol: :lol: and i have another spare diff in stock :lol: :lol:
What's the progress this weekend?
Dirtydog
Re: Feb 15-17
Post by Dirtydog »
Well got bored today so thought i would drive up onto my safari chassis for some articulation, trying to see how much room ill have for larger tyres.
im dissapointed that i couldnt get the front to flex much compared to the back.
certainly better than stock
needs some softer springs though, and aftermarket shocks, as the ones in it are stock safari in the rear, and 30mm lift in the rear.
also took it down to the river for a play, definitly needs better tyres.....
Re: Feb 15-17
Filthy4x4 wrote:Well nothing exciting this weekend, it was supposed to be maintenance weekend :roll: :roll:
$2500 to have my gearbox stripped, checked, reassembled
datsunsafari
Re: Feb 15-17
Post by datsunsafari »
looks like it will be ready for the pig farm next week :D see you there
Re: Feb 15-17
sig
Jeep Jeep
Re: Feb 15-17
Post by sig »
that is an interesting photo jerry
Re: Feb 15-17
sig wrote:that is an interesting photo jerry
the bits that fell out were interesting as well :lol:
Smurf
Re: Feb 15-17
Post by Smurf »
I had that issue, managed to destroy the inside of the FWH also. Both bearings collapsed and allowed to whole hub to move. Wore some nice slots in the brake caliper.
kbushnz
Re: Feb 15-17
Post by kbushnz »
Jerry wrote:Image
So that's why you were having loose wheel bearings....
Ouch.. Glad you got to it....
lax2wlg
Re: Feb 15-17
Post by lax2wlg »
sibainmud wrote:Good to know. You don't have any R180 4.875's front lying around?
Yessir, finally got a 4.8 R180 on the bench, PM sent
Re: Feb 15-17
drove into maratoto and walked around the loop for a look photos later
lexlux
Re: Feb 15-17
Post by lexlux »
how long did that take coxsy .
mudtroll
Re: Feb 15-17
Post by mudtroll »
Bugger walking it :shock: Get your truck fixed Greg & we'll drive it
phraza
Re: Feb 15-17
Post by phraza »
Jeep got a WOF, thats about it this weekend. Hopefully will get it muddy next weekend :D
2WD 06 Hilux... for now
jimichelle
Re: Feb 15-17
Post by jimichelle »
must be the weekend of running gear!
stripped front diff housing replaced all bearings and seals brakes etc
now new battery and tyres and shes good as new
its been the longest vehicle ive ever owned 18yrs all up its been reliable as
only replaced the chassis , body, axles ,springs ,gearbox, motor,radiator driver seat front and side windows bumper bars so far :wink:
shity old hilux
Re: Feb 15-17
Post by shity old hilux »
painted my new chassis and lifting the body off the chassis of my truck ready for new chassis to go under
callum007
Re: Feb 15-17
Post by callum007 »
Dirtydog wrote:Image
Really? it now seems to have expanding foam stuck to the guards, bit of conveyor belt sticking out of its wheel arches and scaff tube welded where a bumper used to be, no indicators and the lighting system from KITT bolted to your roof..
definitly needs better tyres, Possibly I seem to have missed the need for these, do you take it to the supermarket and struggle with the speed humps? I suspect you'll find more articulation on my arthritic dog.
Heath
Re: Feb 15-17
Post by Heath »
Started chopping up the old cruiser chassis.
Removed the wheels/tyres and rear diff (spring bolts were a bastard to get out). Chassis is on blocks now with just the front axle to come out before its is hard out grinder time.
Rear 700mm is now off on the ground (it has a tow bar fitted if anyone wants it but you have to take the piece its bolted to cause I'm not going to unbolt it).
New grinder is working well and those 1mm cutting disks are great, if not a little too quick to vanish, but they work great (better than a hacksaw and are cheap).
I'm going to chop some of the bits up and keep them for steel I will reuse in mounts and odd bits 'n' pieces. The old tray steel is mostly rusted but some bits will stay as it has potential later.
The spare wheel mechanism has been removed. Was going to take the whole crossbrace etc but after messing around for an hour trying to cut through the rivets I decided to just make a new crossmember and unbolted the mechanism (which I'll weld on - or bolt) - havent decided.
Dirtydog
Re: Feb 15-17
Post by Dirtydog »
What a fucktard.
who the f.u.c.k would say shit like that?
go have a wank, or something to get your frustration out. if you have seen any of my threads you would see all the bits on it, and know that i am in the progress of making wider flares.
its not conveyer belt, nor are the driving lights from KITT, nore are they bolted to the roof.
people like this need to get a life man. fuckn hell. your worse than zukmeista.
lincooln
Re: Feb 15-17
Post by lincooln »
swapped the rear shocks for shorter ones for the WoF and also painted the underside in chassis black, sorted some rust and bled the bloody brakes again, still no air out so the pedal travel must be normal. Master cylinder is not leaking so its not that. Oh well, talk with the WoF guy tomorrow.
Lubrication Specialist
Lubrication Engineers
kbjj
Re: Feb 15-17
Post by kbjj »
Pass the popcorn...
Dirtydog
Re: Feb 15-17
Post by Dirtydog »
just pisses me off when people do shit like that, whats the purpose of doing it again?
making themselves feel bigger?
to bad hes picking on a 19yr old thats doing most the work himself.......
J_Dub
Re: Feb 15-17
Post by J_Dub »
What a fucktard.
hook line n sinker.
