Hilux and Landcruiser parts clean out
U-BOAT
Post by U-BOAT »
Have acumulated too many parts and need to get rid of some. Those of you that know me or have been to my place know I've got quite a bit of toyota stuff. Not all parts are in A1 condition, many were to be rebuilt for projects that I now have too many of. All parts are as is where is and no warranty is given or implied. For more information and pricing please PM me.
-Landcruiser rear diff 9.5" 4.11 ratio with ARB locker = made a mistake on ratio :oops:
-Landcruiser rear diff VDJ79 9.5" 3.9 ratio (V8 flatdeck/5 door)) LSD
-Landcuiser 79 series (V8 or 6cyl) rear diff housing bare
-Landcuiser 79 series (V8) front diff housing bare x2 -(locker and non locker)
-Landcruiser 1hz complete running engine with starter and alternator
-Landcruiser 80 bare chassis - no plates
-Landcruiser 80 front diff complete - flange to flange - non locking
-Landcruiser 80 rear dif complete - non locking
-Landcuiser 60 rear diff complete - semi floating
-Surf YN60 solid axle bare chassis with rego on hold
-LN106 shortened wellside with custom towbar and rollbar
-LN106 wellside with toughdeck - dented but useable
-LN106 double cab shell, doors, interior etc - complete
-LJ78 prado rolling body - no diff heads, motor or box rego on hold
-LJ78 factory rear locker 4.88 diff head - needs rebuilt
-LJ78 rear diff housing x2 (locker and non locker)
-YN57? 2wd xtra cab same shape as LN65 bare shell, has all glass
-LN65 2.4d (roller rocker) extractors
-LN/KZN130 IFS front diffs - 4.1, 4.3 and 4.88
-KZN185 R151F 5 speed gearbox only - no bellhousing or transfer
-KUN series hilux or "Sheep shagger" factory steel winch bar
That will get the ball rolling. Have various other parts from LN65, LN106, HZJ70, HDJ80 and can scratch up a few FJ40/45 parts aswell so ask if there's something you may need. I may take a day or two to reply but parts will be sold on a first in basis.
Cheers Marc
wjw
Re: Hilux and Landcruiser parts clean out
Post by wjw »
the 80 series front diff, how much have you got? just the nugget?
Who knew Prados could fly?
mudlva
Post by mudlva »
keen on the 80 rear diff unit
freight up to auckland might be a killer though
are you able to get it to a freight company and if so what freight company do you use
regards
imsohi
Post by imsohi »
Man you got some good things in there how much for 4.88 rear diff for prado
micahb
Post by micahb »
How much??
shity old hilux
Post by shity old hilux »
Got any 4.5 lsd diffs for yn60 surrfchassis or long travel shocks or 50mm leaf springs lift?
muddy
Post by muddy »
Got a CT20 turbo to fit on a 2L Hilux? Already got the manifold...
Bruiser70
Post by Bruiser70 »
What are you after for the 9.5 cruiser 4.11 ratio diff with arb locker setup? How much work has the setup done?
Cheers Rob
sig
Jeep Jeep
Post by sig »
how much for the 1hz cheers sig
