hilux clunk
hilux clunk
drive backwards or slowly foward every no again does a massive clunk and feel it though the floor pulled diff apart nothing in there would it be transfur case????
Re: hilux clunk
have you checked the hanger bearing on the drivesharft? give it a wiggle...
Re: hilux clunk
its a solid drive shaft was one of my thoughts to
Re: hilux clunk
my terrano done this a couple of times while going along the milford road.
could never figure it out, maybe it was a transfer case mount or something perished, but its gone now..
Re: hilux clunk
i had a clunk or bang in my old 96 lux it it turned out to be the center pin on the front spring had broken and it was moving on the diff,
just another thing to check
1980 4x4 Hilux Restoration
Re: hilux clunk
Doing clunk in 4x4 or 4x2 or both? If only 4x4 then could be transfer chain jumping a tooth
Mud Camper
- Bush Crasher
Re: hilux clunk
I had the same thing - a clunk you could feel through the floor, right under the pedals. Mine seemed to happen when the weight slowly came off and then back on the right front corner.
I figured it was the rear spring bushes on the front spring, but when i changed them the old ones looked fine. So I tightened all the chassis mounting bolts while I was under there.
The clunk has gone...... Not sure which fix worked though. Tightening the chassis mounts is easy and free, so perhaps try that?
Re: hilux clunk
cheers ill give all these ago and c what happens.. and just to amswer does it in both 4x4 and 4x2
Re: hilux clunk
i had that on my truck the body mount under where the pedals are had collapsed on the body side fixed it - noise gone.
