Fixing my 4Y
For all topics relating to Petrol engines and modificiations.
Pottzy
Stropper
Fixing my 4Y
Post by Pottzy »
Hi, I have had a problem. I managed to hydrolic my 4Y engine and put a conrod out the side of the block.
To get things running again at a cheap price I have purchased a 3Y carb motor to replace the 4Y. My question is would it be a good option to replace the 3Y carb head with the 4Y EFI head off my buggered motor?
Should I try and keep the EFI or go to carb, will the 4Y head fit on the 3Y block?
Thanks for any advice cheers :? :)
LOLYF
Re: Fixing my 4Y
Post by LOLYF »
from memory when my truck had a 3y in it the head actually had 4y on it :?
Think may be they use the same head :?: any way i'm pretty sure you will be able to use the 4y efi head on the 3y block and it would be good to keep the efi as its heaps better offroad than a shitty old carb.
Pottzy
Stropper
Re: Fixing my 4Y
Post by Pottzy »
LOLYF wrote:from memory when my truck had a 3y in it the head actually had 4y on it :?
Cheers that's what I was hopeing. :D
3VILC
Re: Fixing my 4Y
Post by 3VILC »
Keep the EFI for sure. Im in the process of changing my carby 4Y to EFI
bob_or_jim
Re: Fixing my 4Y
Post by bob_or_jim »
Bit of a tread jack here but it may be of use to you guys. I have a 4Y motor with the injection setup on it here that I will be getting rid of very soon. Sing out if ya need any bits (incl loom)
Smurf
Re: Fixing my 4Y
Post by Smurf »
bob_or_jim wrote:Bit of a tread jack here but it may be of use to you guys. I have a 4Y motor with the injection setup on it here that I will be getting rid of very soon. Sing out if ya need any bits (incl loom)
Where is 'here" could be keen
bob_or_jim
Re: Fixing my 4Y
Invercargill
justin
Re: Fixing my 4Y
Post by justin »
im thinking about it too , got a buggard 3y carb , gota new 3y-e, to replace it , any one got advice?, wiring etc...
thanks
justin
Re: Fixing my 4Y
Post by justin »
well just gotta 32/36 webber carb, with the adaptor ,I know efi is better but ill try this out as it was the cheaper option and ive herd the webber carbs are pretty good, should be running this week ,
mack
Re: Fixing my 4Y
Post by mack »
what sort of adaptor did you get for the 32/36 ? ive just gone down the route myself except ive pulled the 3y out droped a crate 4y in then bought a adaptor plate that i had to modify get longer bolts and longer studs then once the 32/36 was on i made up a custom air cleaner bracket and put a 9" air cleaner on now the big thing with the 32/36 is getting your floats right.
justin
Re: Fixing my 4Y
Post by justin »
hi there this is the adaptor i was told will do the job , copy and past this onyo Ebay -
TOYOTA HILUX TARAGO LITEACE HIACE 1Y 2Y 3Y 4Y WEBER 32/36 CARBY ADAPTOR PLATE.
Its 90 buck aussy and im getting the 32/36 webber .
ill post up when its done, hope this helps, oh yea i got my carb for 250 aussy, how much they go for in nz?
mack
Re: Fixing my 4Y
Post by mack »
i got 2 off mates old man by doing a building job for him i bought my adaptor threw a guy in chch
bob_or_jim
Re: Fixing my 4Y
I still have an EFI setup minus comp here (3Y). Manifolds are bolted to the head still (head is rooted) and has injectors etc. Has loom as well. Come take it away for a box of the brown gold.
Located in Invercargill.
3VILC
Re: Fixing my 4Y
Post by 3VILC »
Got mine all hooked up, runs a million times better than with the carb, like driving a whole new truck. For a box I would be grabbing it if I had'nt already got the bits :)
