New 71 series swb cruiser?
:shock:
juz
Re: New 71 series swb cruiser?
Post by juz »
Dont think there new Jerry, they have had the SWB for years over in camel country. Usually has the 4.0litre V6 I think.
badnuz
Post by badnuz »
tis true of them being available new in camel land, and they are factory TD V8s just like the range here!
basics
Post by basics »
i like it bar the grill :?
99 pajero exceed 3.2
Cleary
Post by Cleary »
basics wrote:i like it bar the grill :?
Put a bar and winch on it...
QUADRACER
Post by QUADRACER »
Recon them doors jwould fit on the older model ?
mudlva
Post by mudlva »
Nice truck. Now to earn a bit more coin to get the deposit to attempt to buy one.....
Coils in front with leaves in the back. Good set up.
As with all the newer lc's prob running 8"front diff but thats sortof all right
Hopefully they didnt scrimp by using drums in the rear as ya cant beat discs in the bush
The 4500efi should push it along quite nicely
Yep i would have 1 if i was aload....
my bad :oops: have edit to 4500efi from td4800
new models should be the V6 version
Big
Post by Big »
QUADRACER wrote:Recon them doors jwould fit on the older model ?
I'd say toyota being toyota it's the same body with the same door skins but slightly diff front end to make it "Newer" and better looking and with better engine options.. I'd even say that you could probably unbolt the fron end and bolt it to an older model no worries..
Just a hunch I have.. :mrgreen: :lol: :lol:
QUADRACER
Post by QUADRACER »
Will found out shortly, local wrecker has one.
charo249
Post by charo249 »
if it is a turbo diesel where is the inter cooler scoop on the bonnet like the NZ models have?
DDAN
Post by DDAN »
My understanding they come out with LC71 is 1GR-FE V6
And HZJ71 which had the 1HZ engines
Return to “Toyota”
