Can anyone help? Iv'e wasted 2hrs googling already
What Model Falcon Calipers For Hilux Axel Disc Conversion??
Saw some Falcon rear calipers (solid disc with handbrake mechanism included) at the pick-a-part a couple of weeks back, and can't remember the model, now it's gone
The Handbrake mechanism didn't stick out like the Subaru Leone ones.
- niblik
- Sausage Shack
Re: What Model Falcon Calipers For Hilux Axel Disc Conversio
Must be a falcon orientated wrecker about we could have a hunt in fulla?
Yeah, I'll be on the phone tomorrow, I know of a one out Eyreton way
also the dude beside jamie he wrecks coons too
Just did a quick search J (5 mins
) and found that the EA coon seems to be the one. Having said that these guys are using 2wd Hilux axles for other applications so they are using the 5 stud discs from the coon as well. Some are saying the XD/XF calipers work but they are using EA handbrake levers. Don't have any idea what that means is the real world, but it may make sense to you.
dont know if it helps but got ea set up on rear of my pig........
v8 tj...luvs the gas......
Hey, just another option for you. If you use the soild disks off the front of a hilux, 90-91 v6 maxima calipers work with a flat 10mm plate bracket. The factory hilus brake cable fits witha small peicr of flat bar welded in to the caliper lever.
meatc wrote:Hey, just another option for you. If you use the soild disks off the front of a hilux, 90-91 v6 maxima calipers work with a flat 10mm plate bracket. The factory hilus brake cable fits witha small peicr of flat bar welded in to the caliper lever.
Yeah saw that, but not sure if welded caliper lever is wof-able
rokhound wrote:Just did a quick search J (5 mins) and found that the EA coon seems to be the one. Having said that these guys are using 2wd Hilux axles for other applications so they are using the 5 stud discs from the coon as well. Some are saying the XD/XF calipers work but they are using EA handbrake levers. Don't have any idea what that means is the real world, but it may make sense to you.
Cheers, I did find that stuff, but they don't look like the ones I saw. After images of each model as I'm a visual type of guy
yeti wrote:dont know if it helps but got ea set up on rear of my pig........
Have ya got a pic of the handbrake side of caliper?
- IcedJohnno
- Trailer Trash
vvilly wrote:also the dude beside jamie he wrecks coons too
His name is Robbie, the business is Falcons n Cruisers.
Shares the same site as Jamie, 32 Edwards st, Goontown.
He's a nice guy. I work with him, usually one day a week, out at Daiken.
will get a couple 2moorow.....txt em to ya
I've fitted xf rear callipers to a cruiser fully floater hsg, and they worked ok. I think ea falcons have handbrake shoes inside the disk rotor like the 80 and prado.
IcedJohnno wrote:vvilly wrote:also the dude beside jamie he wrecks coons too
Cheers John, he's the guy I plan on ringing. Delt with him before, great guy, reasonable prices, easy to deal with
i know eb and ed models(early 90's) falcons and fairmonts used disk hand brake. but the round seal behind handbrake mech lever was prone to popping out. used to #### me off, emergency stop once, all good, nec minit, no more brakes(via pedal). hahaha. ended up modifying the plate so it covered more of the seal.hope it helps.
