KZJ78 Failed LVVC.- Rim Width
Henry
Post by Henry »
Hi
My KZJ78 failed a WOF because of shock mounts and the 3 inch lift.
So it needed a cert.
So off to the man for a cert and it failed on the rim width....
see
http://www.lvvta.org.nz/documents/infos ... _Guide.pdf
I need a 8 1/2 inch wide rim for a 33 X 12.5X 15.
they make a 8 or 10 inch rim....
10 is too wide for my prado.
So off to Elite wheels in chch to get a 9 inch rim from a 8 inch set I had in the shed....
Then off to the powder coaters.
And maybe a new WOF in 2 weeks or so....
sig
Jeep Jeep
Re: KZJ78 Failed LVVC.- Rim Width
Post by sig »
thats interesting .I,m about to get my prado certed and they dont even list 35s :shock:
T-Boon
Post by T-Boon »
We have the exact same problem with the "Stretched tyres" on race/road cars. Get the NZ distributor to make up a guide for correct fitments on your rim and you`ll be fine.
To Boon or not to Boon.
Henry
Post by Henry »
PM sent
tallsam66
Post by tallsam66 »
What brand are your tyres?
I got cert no worries with 33" on 8 inch rims.
jonossiksilvia
Post by jonossiksilvia »
i too got cert on 8 inch wide rims with 35/12.5/15
Madaz
Post by Madaz »
jonossiksilvia wrote:i too got cert on 8 inch wide rims with 35/12.5/15
Me Too, What BS..........
mike
Last minute Mike
Post by mike »
where did you go for cert? I don't want to go there as I'm due for cert in the near future .
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
Dirtydog
Post by Dirtydog »
my cert man said it doesnt matter if i get my 33x12.5s on 7 inch rims.......
Henry
Post by Henry »
The tyres are BF Goodrich 33 X 12.5 X 15.
The real issue here appears to be BF Goodriches Rim size recomendations.
the NZ site is down but the Australian site recommends a 10 inch rim with a minimum of 8.5 and max of 11.....
And as every one know who has bought steel rims - 8 1/2 inch rims don't exsist....
Mike I sent a PM....
Henry wrote:The tyres are BF Goodrich 33 X 12.5 X 15.
has your mate got a set of 33's on some 8" rims that have a recomended rim size of 8" :idea: thats a lot of fawking around and cost for a one off tick on a piece of paper :?
turoa
Pyro Junior
Post by turoa »
8.5" alloys do. I think you'll find most certifiers will be getting strict on this kind of stuff. Just covering their asses really. Not worth being dragged behind a bus
Madaz
Post by Madaz »
Just to confuse things a bit more, my hilux got certed on 8inch rims, cert plate turns up and it states that it has 15 x9.5 rims on it? :idea: :lol: :?:
Question the certifier about it and he get a tape measure out and measures the complete width of the rim........... which was or is on a 8 inch rim about 9.5 inches????? Crazy????
But really isnt the point of a low volume cert in making sure that the mods you have done are safe for the vechicle being certed?
You should be able to run any realistic rim/tyre combo as long as all the other boxes are ticked? eg tyres covered by flares, fouling on other components ect.
surf lux
Post by surf lux »
I got cert for my ln106 with 15x10 inch rims and 35's Kumho KL's
only thing needed was a set of flexi flares and the cert guy was happy
even though the tyres were borderline sticking out past the flares, depends where you take it I guess.
Tarmac
Post by Tarmac »
like Sadam_Husain mentioned can you "borrow" a set of rubber with an 8" min reco width to achieve cert? Even though they are the ones in the firing line sounds like picking the peanuts outta poo to me... 33's are 33's arent they :wink:
Would offer to lend mine but they are fact 5.5 SJ rims with 30 x 9.5s :roll: (like they do around corners) I guess a cert is diff to a wof
3VILC
Post by 3VILC »
That really does sound like they are nit-picking a little too much. Not picking anything in your method here, but they would rather cert a widened rim than a slightly smaller uncut rim? Strange.
I ran my truck for a good few years with 33x12.5s mounted on standard 15x7 rims, used to be a little slopply on corners but no major drama
Henry
Post by Henry »
Yaaa
finally passed cert and got a wof.
After fitting the rims I looked at the flares and thought . He will fail me now because the tyres are out side the rims.
So i went the Bunnings Garden edge way and $35 dollars later all ok.
I did get a fright when he said that they normally need a photo of inside the rim before it is painted..... So do that if you are getting a rim modified....
Henry.
Knowlesie
Post by Knowlesie »
in reply too a few people earlier in the thread regaurding getting certs in christchurch no worries , who were you going through ?
Return to “Toyota”
