Inspect you towbar every now and then
All aspects of safety with 4wds from proper mounting of tow hooks to recovery situations.
Rotazuk
Post by Rotazuk »
Since most people use there 4x4 to tow I figured I would post this up here .
Short story is my co worker pulled his tow ball off to steal my 50mm ball . When he removed it , it was loose and hard to remove the nut . Thats because the shank was bent , due to it being a 3/4 shank ball in a 7/8 tounge . He imported the vehicle from Japan and had the towbar installed by toyota :shock:
Also we had a major getting the removable tounge out , after said worker said he had it out not so long ago ( transpired to a couple of years ) . It finally came out but is rather rusted and not in good shape .
So keep an eye on your tow balls and make sure they are not loose and if you have a removable tounge either only install it when needed or remove them frequently and rust treat them .
Chris
callum007
Re: Inspect you towbar every now and then
Post by callum007 »
And check the bolts on the bar!
My dealer fitted bar seemed to have 4/10 bolts only hand tight after 2 months. Even last week, vehicle is nearly 3 years old, I got another turn out of half of the bolts. Granted I do often carry heavy loads, but can you recall the last time you checked yours?
QUADRACER
Post by QUADRACER »
Factory tow bar on my 2011 ford ranger had elongated the removable tongue
Around the pin, only done 28000 Kms .
Notice the new model has a different design .
Suza
Post by Suza »
I do a lot of heavy hauling and replace the tow bar mounting bolts every 2years and the tow ball. Properly over kill but it makes me feel better. I also I also check them for tightness (including tow ball) every service. I also change between 3 balls regularly depending on what I am hauling - 1 7/8, 50mm and 60mm, when I change them I always check them after a 10or so km's down the road
mudlva
Post by mudlva »
Suza wrote:I do a lot of heavy hauling and replace the tow bar mounting bolts every 2years and the tow ball. Properly over kill but it makes me feel better. I also I also check them for tightness (including tow ball) every service. I also change between 3 balls regularly depending on what I am hauling - 1 7/8, 50mm and 60mm, when I change them I always check them after a 10or so km's down the road
i bought a interchangeable ball system from appco
as im going from 1 7/8 to 50mm all the time
they come out as std 19mm or 25mm stud
this save changeing the complete unit all the time and the ball locks in place by a 1/4 turn and a locking tab
the 25mm unit is rated to 3t stamped onto the base, pretty encouraging as std towball units dont normally have anything stamped on them
Suza
Post by Suza »
I looked at something similar a while ago but because I use 3 different size's and 60mm is odd it didn't work for me
callum007
Post by callum007 »
From memory, those change-a-ball things come factory on newer landy disco's. well thats were I got one from, very handy
Return to “4wd Safety”
