Filthy Safari
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
No real update...
have had it out a few times since fitting the new tahs, runs like a dream.
Got sick of the diff seals leaking so had a mate redo all the seals and king pin bearings, drives like a dream now :mrgreen:
Hangin out for some rain, but using the time to catch up on maintenance and repairs/mods.
027 MUD GEAR - (027 683 4327)
Check our facebook:
Re: Filthy Safari
sweet tyres check ya seat mounting bolts while your doing stuff most ofmine were loose to needing a tad tighting up :lol:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
:lol: :lol: Cheers Coxsy will investigate the seat bolts while im at it :mrgreen:
Check our facebook:
Drurban
Re: Filthy Safari
Post by Drurban »
Also get a flexi spring for your aerial, that way you wont keep breaking them :lol: :lol: :lol:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Drurban wrote:Also get a flexi spring for your aerial, that way you wont keep breaking them :lol: :lol: :lol:
Fitted one of those a few weeks ago :wink: am just waiting on my High Gain aerial now 8)
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Well, I suppose I should give an update...
Ive been out wheeling it a fair bit (never as much as wanted).
Damage List:
Wing Mirror
Hubs x 2
Glow Plug Relay
Gearbox
Alternator
Batteries x 2
Shes taken a fair beating but just wants to keep running.
Have added some fancy switches:
Oh and one of these appeared in the engine bay :mrgreen: :mrgreen: :twisted:
What a huge difference, am yet to give it a tune and finish the exhaust.
Am attempting to fit the PTO winch setup I bought before the weekend rolls around so fingers crossed I can tick that off the list also, the it'll be off to CP Racing to get some bar work done hopefully :mrgreen:
Check our facebook:
datsunsafari
Re: Filthy Safari
Post by datsunsafari »
you forgot a few things for your damage list.......grill, front indicators x2,head light, front guards x2, rear quarters x2 :wink:
eins
Re: Filthy Safari
Post by eins »
Nice turbo! Were did you get your switch from?
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
:mrgreen: so I did...
The list will continue to grow too :lol:
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
eins wrote:Nice turbo! Were did you get your switch from?
BNT sell them dude. Its a Narva Switch
Check our facebook:
skidmark
Re: Filthy Safari
Post by skidmark »
^beat me too it
looks like one of the new switchs from narva.They have a whole range aimed at 4wds now http://www.narva.com.au/products/browse/4wd
eins
Re: Filthy Safari
Post by eins »
The Narva 4wd ones are only 12v so I guess they will not work the on Safari being 24V If going to buy switch like that really one the illumination to work
skidmark
Re: Filthy Safari
Post by skidmark »
can fit a resistor inline with the illumination(think narva even sell them.maybe might be one of the other guys) to allow them to be used on 24v or use the led ones with a stickersheet http://www.narva.com.au/products/browse/led
DaveM
Re: Filthy Safari
Post by DaveM »
eins wrote:The Narva 4wd ones are only 12v so I guess they will not work the on Safari being 24V If going to buy switch like that really one the illumination to work
http://www.ebay.com.au/itm/140815746630 ... 1423.l2649
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
These are 24v switches which come blank and you buy the sticker sheet separate with about 50 different designs and logos.
The difference between the switches are the illumination bulbs... 12v = Bulb, 24v = LED.
Good switches I'll definately be buying more.
Check our facebook:
CLUMZ1
Re: Filthy Safari
Post by CLUMZ1 »
rough cost of an LED switch? i want some
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
I think it was about $20+ for the switch and $6+ for the sticker pack.
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Huge thanks to Andy for the help in the weekend we got a fair bit done.
So I got a new 4" Grinder and needed to test it out on something... I turned it on and it was so powerful it just sucked my truck into it :shock: :shock:
and this happened: :mrgreen: :mrgreen:
Then the rain came down, we were determined not to stop to made a shelter :lol:
I take my hat off to all your sheet metal workers, panel steel is a pain in the ass to weld... The smallest I know how to weld is 6mm :roll: this was my first time doing any panel work...
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Suppose Im due for an update...
Have been slowly chipping away at it when time allows.
Figured out that the reg was stuffed on the welder so went and grabbed a new one and grabbed a bottle of Argoshield Light too see if it would make a difference... I am very impressed with it, welder is now much more enjoyable to use on the panel steel :mrgreen:
Decided to take a break from welding for a day and made up the rear panel
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
After waiting out the rain, it cleared up nicely this arvo so jumped outside and welded up the rear panel on the truck :mrgreen: :mrgreen:
Hoping for more good weather tomorrow so I can grind it all back and tidy it up 8)
Starting to take shape now :mrgreen: :mrgreen:
Check our facebook:
Im a Tumor
Re: Filthy Safari
Post by Im a Tumor »
Wow awesome work man, I hate welding panel steel too!
What made you decide to turn it into a ute? or was it always the plan?
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Thanks mate, Yeah it was sort of one of the plans I had in mind for it.
I kept smacking the rear quarters in all the time, and I want to have a go at Winch challenge this year (fingers crossed) so I figured it was easier to chop it now and build the cage to suit rather than cage the full body then have to redo it later on...
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Well I almost cooked myself today, working in dark overalls in the sun isnt on my to do list again :shock: :shock:
Felt like I got nothing accomplished but spent hours on fiddly jobs and trying to make it look presentable :roll: :roll:
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
More progress being made... slowly but surely...
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Check our facebook:
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Check our facebook:
shortylux
Re: Filthy Safari
Post by shortylux »
Nice! you have that panel steel welding on lock! Guna be a cool truck.
Filthy4x4
Re: Filthy Safari
Post by Filthy4x4 »
Cheers dude, im actually just getting better with the camera :lol: :lol:
Certainly looking forward to finishing off the body and getting started on the bar work.
Check our facebook:
kbushnz
Re: Filthy Safari
Post by kbushnz »
I am surprised you haven't set fire to it already what with the amount of stuff (I use that term lightly) on the floor of your cab ahhahahaha lol
