Easiest way to replace ilder bearing in GQ?
For all Nissan related topics
Craydiver
Post by Craydiver »
the idler bearing in my 88 GQ TD (no turbo) is getting noticeably worse since when i brought it 4months ago. ive checked various threads - and it appears that pulling the motor is best way rather than pulling gearbox back.
Are there any key issues/tricks i need to be aware of when pulling eng?
Also - if i continue to drive and idler fails, will it cause damage to clutch?
crazyclark31
Re: Easiest way to replace ilder bearing in GQ?
Post by crazyclark31 »
If your idler is stuffed chances are the clutch will be on it's way out to.
I have found the engine out is the best way to change them.
mudlva
Post by mudlva »
its a super heavy iron thing on one side and a even heavier iron thing on the other
if you have access to a hoist and a trans' jack then pulling the gearbox would be the go.
if not then the motor is the next best, just be aware that the motor is way heavy
Return to “Nissan”
