superwinch problems
benorange
superwinch problems
Post by benorange »
just installed my superwinch on new truck that I have had sitting round for few years. I wound out the cable to make sure its ok but as I wound it back in the winch kept stopping then would start again it didn't do this last time I used it.
I tracked the problem to a row of square things on the main power feed from battery, they would get warm then click and stop then give it a while they click back on. the longer I left it the better.
Do I need them? if so what are they called and where do I get them.
kbushnz
Re: superwinch problems
Post by kbushnz »
Throw up a photo, but they sound like relays....Might be corroded inside from sitting too long....
benorange
Post by benorange »
no not relays these things only have two conection points there is about 6 of them in a row on strips of alloy power in one side and out the other
meatc
Post by meatc »
Sound like a resistor or simliar, I cant see why you would want them, perhaps its a 12v winch and came off a 24v truck, weird. only thing that should be between batt and winch is the solinoid Pic would help
sibainmud
Post by sibainmud »
They sound like thermal operated self resetting breakers. Can be 50 amps a piece. Symptoms would indicate 1 or 2 may be crook or the winch is using more than the prescribed amount of amps.
Return to “Tool Shed”
