terrano starter motor removal
For all Nissan related topics
grytvikken
Post by grytvikken »
Hi anyone got any tips on how to get the starter motor out of a diesel D21 terrano.....had a quick look and it looks like it could be a pain.
lax2wlg
Re: terrano starter motor removal
Post by lax2wlg »
I went in from the top, removed p/s reservoir & bracket from the body & pushed hoses aside to get access.
Tarmac
Post by Tarmac »
Like anything, long and short sockets, a variety of extentions, ring spanners also a variety of crows foot, plus some extra skin for your knuckles... :lol:
grytvikken
its a prick to get out by the sounds of it
sibainmud
Post by sibainmud »
Get a body lift, out and in 1/2 hour :mrgreen:
On a serious note, prick of a job. I find the best way to get at bottom bolt is to come up from under with a few long extensions and a uj. There is a sweet spot over front diff and under the engine mount.
Best of luck.
Crash bandicoot
Post by Crash bandicoot »
undo right engine mount, tilt engine over wouldn't work?
slide
Post by slide »
Get creative with extensions and swivel joints, and spanners. After starter unbolted, tie a bit of rope to it, use rope to lift it up out the gap next to brake booster/inlet manifold. Take note of the way it comes out, lower it back the same way. If you think its bad, try a v6 terrano :lol:
LOLYF
Post by LOLYF »
slide wrote: If you think its bad, try a v6 terrano :lol:
And if you think thats bad try a V8 hilux :lol:
See that little hole in the back of the valley? thats where it sits and the 2 bolts that hold it in come from the firewall side :roll:
The Stranger
Post by The Stranger »
lax2wlg wrote:I went in from the top, removed p/s reservoir & bracket from the body & pushed hoses aside to get access.
I took the front right wheel off and went there.
Wasn't too bad at all really - well compared to say a P10 Primera where it's on the LHS of the car and the only way to reach it is to remove the RHS wheel and you have to do the whole job with only one hand and you can't even see it.
skidmark
Post by skidmark »
im sure ive done a few at work, and as they say some extensions and universal and spanners, then pull the starter out the top close to the brake booster by memory?
Return to “Nissan”
