Truck is a lwb safari. 2in lift 33s but no lockers,winch,have front,and rear bar work and sliders to. Do have a thinking driver tho
Basically after a bit of a challenge/mission for an arvo. Have all my recovery gear incl ground anchor.
Mike
jt3000 wrote:Is this worsley on the port hills in CHCH?
I've got a surf with a 2" lift and 32 AT's - cautious beginner driver.
Edit: Just read another couple of threads on this track. ha ha might give it a miss till i know what im doing. Might go for a nose tho (on foot!).
ef9 wrote:id be keen to go up,, landy on 32'' should make it up..?
mike wrote: Wet, well then all cards are up in the air and I'd just follow hosehustler
a landy will go anywhere just on coolness factor alone![]()
