1969 Patrol G60
jervisad
Re: 1969 Patrol G60
Post by jervisad »
this is looking very cool 8)
robssei
Re: 1969 Patrol G60
Post by robssei »
jervisad wrote:this is looking very cool 8)
Cheers mate!
robssei
Re: 1969 Patrol G60
Post by robssei »
Machined up new steel bushes for leaf spring shackles. There were tired nolathane ones in the rear, and after reading in manual that stock ones were steel , Decided to make some. OD is 22mm, ID is 16mm, lenth is 56.5mm. Fitted nicely with new spacers. i used conical spacers so they had less contact area with bush and shackle. They are a press fit on spring and mount, and a loose fit on shackle.
New bushes
old versus new (fronts were still origional steel)
fitted on shackle to check
finished
tool i made to press originals out, also use parts of this to adjust draglink.
Dirtydog
Re: 1969 Patrol G60
Post by Dirtydog »
its funny how often blocks of wood are the best too for the job....
and that tool looks interesting, what does it consist of?
robssei
Re: 1969 Patrol G60
Post by robssei »
A large socket, a 5/8 unc stud, tslot, and nut, and the extra bush i made as a spare. Yes, wood is invaluable.
bobthepainter
Re: 1969 Patrol G60
Post by bobthepainter »
very nice old truck, this would be well liked by the oldschool.co.nz crowd.
robssei
Re: 1969 Patrol G60
Post by robssei »
Heres a pic of the beast at a Greerton Car show, i won a digital camera was stoked!
and heres rear lights done, tray welded, needs decking now!
robssei
Re: 1969 Patrol G60
Post by robssei »
Chopped! Love it, need ideas for deck! so many options, ply, hardwood ply, quila or similar decking etc, tub it! ha need ideas!
robssei
Re: 1969 Patrol G60
Post by robssei »
New tray lining been fitted, rough mock up at this stage
mercutio
Re: 1969 Patrol G60
Post by mercutio »
looks good to me :D :D
my 4wd is not a truck
robssei
Re: 1969 Patrol G60
Post by robssei »
Yeah i think the rough sawn timber keeps with the rest of the Patrol, bit rough!
surf10
Re: 1969 Patrol G60
Post by surf10 »
very kool love seeing these old trucks come out of the wood work
oldyella
Re: 1969 Patrol G60
Post by oldyella »
I build a flat deck from scratch for the LR. A couple of pics are below. Things I would do differently are:
Weld the hinges for the sides the right way around. You need to weld them on so, if a side is not "up" but instead is folded down, that it doesn't slide off when you accelerate.
Yes there are pros & cons but if I was to do it again I would do it that way around.
Part done with hoop
All finished
I used 12 mm ply with some deck stain from Resene. I used stainless fixings and just black enamel paint with etch primer underneath.
Another thing is I didn't build it to any "spec". If you want to enter any decent competition, do some reading and build it to a specification, it will be worth it in the long run I think.
Finally, if you have a boat with a short drawbar, make sure the deck overhang isn't excessive. Else, if you turn to sharp, you may damage the boat.
At the moment I can't tow the fireball :cry: Major fk up...
Pete
robssei
Re: 1969 Patrol G60
Post by robssei »
mate thats good advice, looks good! staying flatdeck without sides. i like that look you got, i was looking at hardwood ply too but quite pricey. this deck is a practice one, can get hold of some quila decking.
oldyella
Re: 1969 Patrol G60
Post by oldyella »
It would look good with some hardwood decking.
If you decide you want sides, I got the hinges, pins and latches from TWS
A rope bar is also a handy thing. Its missing on mine but I am thinking of adding it on the top of the sides
Pete
robssei
Re: 1969 Patrol G60
Post by robssei »
yeah my workmate has some hardwood decking i can have, decided that will look too good to pass up. a rope bar is a good idea!
tintin
Re: 1969 Patrol G60
Post by tintin »
robssei wrote:yeah my workmate has some hardwood decking i can have, decided that will look too good to pass up. a rope bar is a good idea!
Hardwood decking would look awesome on there, does he have much i would be keen buying some for on my sides and tailgate.
1980 4x4 Hilux Restoration Image
robssei
Re: 1969 Patrol G60
Post by robssei »
went and checked it out, he doesnt have enough to do the whole deck. going to work with what i have or see what else comes up. still have some work to do rust proofing on chassis etc, so its handy having deck not fixed down.
took her for an offroad trip, with a mate, decided its going to be the last heavy trip it does, took me so long to clean all the mud out of her, to get her mint and clean again. its to rare to use for heavy offroad. looking good though i think!!!
robssei
Re: 1969 Patrol G60
Post by robssei »
adjusted clutch presurre plate forks, bled and overhauled slave, and welded and redrilled pivot point. still have to double clutch but clutch system is perfect. syncros gone i belivev. on another note, top off! found first rust yet, few small holes in windscreen , under where fibre glass roof screws on. minor stuff. driving it to work was awesome! but was chilly!
robssei
Re: 1969 Patrol G60
Post by robssei »
I refixed roof on, with rubber strip as isolation between the joins on tub and windscreen to prevent vibration. Heres some new pics, gave her a cut and polish, followed by a wax. suprised how the paint came up! also secured deck down and coated it with polyurethane. I was going for a old school kinda look ie old farm truck, and im happy how it looks. didnt want the the deck to outdo the paint! also tinted some antirust primer to paint the brake master cylinder area. got the color pretty close. looks alot better.
Mehrts
Re: 1969 Patrol G60
Post by Mehrts »
That's one verrrry tidy engine bay! Well done for what you have accomplished so far, keep it up! :wink:
Toyhatsu Bitsalux
robssei
Re: 1969 Patrol G60
Post by robssei »
I have done alot more to engine bay etc. its a pita to resize pictures on my phone so here's a link to my build thread on oldschool.co.nz no comments to wade through just progress
http://oldschool.co.nz/2011/forum/index ... g60/page-3
