more power out of 2.5 diesel turbo ford courier
ratbagjamie
Post by ratbagjamie »
has any one done any cheap simple mods to one of these engines to get more power with out going over board? I feel its gutt less in 4wd hi when off roading?
zukmeista
Re: more power out of 2.5 diesel turbo ford courier
Post by zukmeista »
Use low range instead maybe?
used the boss's 2wd turbo diesel today, more stick than my std 2.5 non turbo, see if they have boost pressure release block that and try find the fuel screw
hamboy
Post by hamboy »
These things can be lifeless below 2000rpm, make sure the fuel and air filters are up to date, then get rid of the EGR system.
NJV6
Post by NJV6 »
hamboy wrote:These things are lifeless below 2000rpm
Fixed it...
Just have to drive them between 2000 & 3500 for best results, done lots of km in them, as soon as offroad, into lowbox as zuk said.
Just got to keep them boosting cos when they are they got heaps of grunt.
ratbagjamie
yeah I had to use low up the beach just want to get more out of it
44jetboat
Post by 44jetboat »
brother had a 2.5 2wd. we blocked the egr installed large front mount intercooler and played with the injector pump. uped the fuel and boost compensator. went really well after that. set the max ext temp to 700deg pre turbo. just to be safe.
