PTO transfercase drive gear LJ78/KZJ78
micahb
Post by micahb »
PTO transfercase drive gear wanted. any idea where i can find one? mine doesnt have one and been looking for one for a while. Will one fit from any toyota PTO drive? My search would broaden dramatically if they are all the same.
Re: PTO transfercase drive gear LJ78/KZJ78
you need the drive gear and the short spacer as well
kbushnz
Post by kbushnz »
Gear from the older 70 series fit (same transfer case)
You can recycle the longer spacer that's currently in there and have it turned down on a lathe..Just remove the thickness of the gear....
Big
Post by Big »
you might find it a little harder to find nowa days.. I thought I had one spare but can't find it.. got the spacer and idler.. but no gear :lol:
ClassicCruiserSpares
Ive got heaps of them down here :D flick me a pm if you want one.
micahb
Post by micahb »
ok, well i haven't been able to get one off CCS, so anyone else got one?
Cheers.
Big
Post by Big »
bugger.. I might be able to get one for you.. ill make a call :lol: :wink:
mudlva
Post by mudlva »
try Don Kyatts in manukau city, they have the gear in there parts book, so it should be available
kbushnz
Post by kbushnz »
mudlva wrote:try Don Kyatts in manukau city, they have the gear in there parts book, so it should be available
Yip they can get them... but big $$$
Big
Post by Big »
nope he only has one and he's using it.. sorry :roll:
mudlva
Post by mudlva »
how much is big bucks?? i would of guessed $50 maybe $80 ish???
or am i just dreaming....
kiwicruza
Post by kiwicruza »
Hi micahb. I have a spacer and pto gear that I removed from a HZJ73 (1993 mid wheel base with 1HZ motor, manual gearbox, usual split transfer case) that I don't need. A1 condition - never had pto winch etc.
I removed them when I replaced the transfer case input gear with one of the aftermarket long spline ones to get around worn splines on input shaft.
Happy to move it on at sensible price. You'd just need to check transfer cases were the same but from info above it appears as if it is. Get in touch if you're interested.
kbushnz
Post by kbushnz »
Its $220 odd via Aussie and its on back order in Aussie....
mudlva
Post by mudlva »
ohhhhh :shock:
Return to “Toyota”
