Oil pressure- td42t
Oil pressure- td42t
Righto biting the bullet and going aftermarket oil pressure gauge.
Can anyone tell me what the maximum pressure they would see on the td42 at anytime?
Just so I know which gauge to get- 0-80psi, 0-100psi, or 0-150psi.
Glenn
Glenn
Re: Oil pressure- td42t
i havn't got the manual for that engine on me at the mo. but i think its probably around 80psi max. so go for a 0-100psi gauge.
Mint cheers dude.
Hello trademe!
Hello trademe!
Generally about 3-4 bar pressure and running mine drops to 2.5 bar at idle when hot
coxsy wrote:Generally about 3-4 bar pressure and running mine drops to 2.5 bar at idle when hot
what oil are you running?
Buggered if I know yet, had the truck about 4-5 weeks!
Speaking of oils any particular oil you guys recommend for these?
Penrite at the mo. oil pump carried over from the old engine
Gren wrote:Buggered if I know yet, had the truck about 4-5 weeks!
not to sure, don't run the TD42 myself (zd30 instead). but i've switched over to gulf western J-power 15w-40 on the toyo. its running great, a lot less blowby to.
the j-power is a jap spec high ash oil so i think it would work well on the TD42.
coxsy wrote:Penrite at the mo. oil pump carried over from the old engine
what penrite?
with that oil pressure i would suspect 20w-50 or even 60 !
15-20
coxsy wrote:15-20
typo? i don't think they make that.
That's what printed on the ten litre drum, near due for oil change anyway
Eek! A little thin for an engine that's done somewhere between 390-430k wouldn't you say?
Actual kms unknown due to ODO only increasing 90kms over last 3 owners.
coxsy wrote:That's what printed on the ten litre drum, near due for oil change anyway
got a pic?
should have the name on there as well.
Gren wrote:Eek! A little thin for an engine that's done somewhere between 390-430k wouldn't you say?
which oil are you referring to?
15-20w full synthetic.
i don't think its a 15w-20. penrite don't list one that i can see and 15w-20 is an odd spec oil. a 5-20 maybe or 15-30.
a 20 would give really low hot oil pressure when hot even on a fresh engine.
15w-40 would be a good place to start. maybe a 50 if its well worn and giving low oil pressure.
just remember that high oil pressure = low oil flow and flow is whats required to protect parts.
TYPO
What I'm know for duh
15w-50
HPR diesel
Not well worn engine 4k to engine rebuilder plus parts
15w-50
HPR diesel
lol join the club
yeah 15w-50 is like pumping sludge. ok for a worn engine or hot climates but i would be running a 15w40.
Finding oil is a lottery at best when buying eleven. Litres for oil change
I run tota,l mines down 230km I just turbos it 5000km ago and have not driven like a nana either! And seems to have a bit of blow by when stopped at the lights but has not dropped at all on the dip stick I run total in diffs, t-case and g box aswel the old girl just loves it. Not the cheapest tho but I don't mind paying little more for the good stuff when it's the blood of my td42
I run shel rimula rx3 15w 40 in my td42t goes good as. better than it did on caltex delo.
Buggerd if i know the oil presure is my gauge abit stuffed some days it works others it dosent move
Mr Phux It
