Petemcc wrote: Na if you are going to get into it you will want to do some mods pretty soon you are better must to buy something that has had a lot of the work done already or you will spend all of you time and money modifying it. Much cheaper to buy someone elses.
All well and good if done properly. Buying an already modded truck you can also be buying someone elses problems. At least if you start from scratch you know what's being done is being done right.
Depends on what it is youre prepared to do, how much time/money you want to/have to, spend on it.
