GME GX300 in D21 Terrano.................
BogBoy
Post by BogBoy »
Hey all
I have a GME GX300 in my D21 terrano.
Its brand new along with the cable/base/mount/whip
It wont pick up a signal as I start moving. :evil:
The guy who sold it to me also installed it and its got him stumped.
Any ideas?
callum007
Re: GME GX300 in D21 Terrano.................
Post by callum007 »
Its in a terrano, that may be the cause....
Does the installer have a clue what he was doing? SO many different reasons for it not to work.
Poor grounding, grounding a ground independent aerial. short on coax, stuffed tx out of box (does happen), squelch too high, dead speaker?
So works fine when stationary? did you move too far away from what your listening to? your electrical system is shit (terrano) and your overloading the receiver? did you test the aerial with a swr meter?
Try a noise filter. Get a professional to look at it....
All else fails, leave it in the drive way where it works.
BogBoy
Post by BogBoy »
callum007 wrote:Its in a terrano, that may be the cause....
Yea the guy who installed it is a professional, First thing on my terrano that I have had done by a professional and it doesnt work...
Na I follow my mate in his and we have switched his CB with mine, same problem so i'm leaning towards a bad earth.
I will tackle it tomorrow if its not raining.
callum007
Post by callum007 »
BogBoy wrote:Yea the guy who installed it is a professional.
Yeah.. Na, a pro wont scratch his head. We make up a bull sh*t excuse and try something else till we find what it was. Run it from the battery for a test. Check for a short on the aerial. Give me a little more to work with..
wax
Post by wax »
Hooked it to the speedo sensor.
BogBoy
Post by BogBoy »
Ok so its earthed to the same wire the CD player is hooked up to. :?:
Was thinking about testing for earth at the base of the antenna/whip.
This really has me confused as far as I can see it should be a simple set up :(
BogBoy
Post by BogBoy »
Got it sorted
Turned out the cable that was supplied had a break inside it.
The unit seems to favor the higher channels too
Return to “Tool Shed”
