heavy duty idler arm for surf
truckingood
Post by truckingood »
as per title, dose any one know where I can get one? has any one made there own?, cause the biskit base or cheese they make the oem ones out of is just shit :evil: I no of one out fit in oz that do them but will try here first. ta luke
SamLogan
Re: heavy duty idler arm for surf
Post by SamLogan »
i had never heard of any in nz but that was a while ago i last looked. there is a place in the states that make a brace for them but they are for a left hand drive vehicle. could be something that you could mirror and make work.
Sam
lexulance
Post by lexulance »
I had one made by MS Coombes enginering in chch,had a 24mm shaft made of some very high grade steel,they even put a grease nipple in it for me,never had the problem again,cost me $270incl
truckingood
yea I have read of guys using lhd steering boxes too, there is a place in oz called superior engineering who make them just waiting to hear back, think my best bet so far is to weld 10mm plate top and botttom
truckingood
lexulance wrote:I had one made by MS Coombes enginering in chch,had a 24mm shaft made of some very high grade steel,they even put a grease nipple in it for me,never had the problem again,cost me $270incl
yea it not the shaft it self im having probs with its the arm that connects to drag link. its flexing up and down about 5-7mm causing wobble out at the wheel
tweake
Post by tweake »
is the arm actually bending or just flexing on the bushes?
some people fit bronze bushes in.
what mods has the front suspension got?
Smurf
Post by Smurf »
Is the arm flexing or is it moving due the the bushes being flogged out in the idler? The bushes are replaceable.
Some idlers have a thicker shaft and are a bit harder to bend.
Toyota used to have three different sized bushes listed, two for a thinner shaft and one for the thicker shaft.
I bent countless idlers on my old IFS Surf (LN61) running 33s and replaced bushes almost 6 monthly, until I got hold of one with a thicker shaft, it lasted a few years.
Roenut
Post by Roenut »
Just bent mine too (kzn130)
Do you know which trucks had the thicker shafts smurf? Or is it simply a difference between manufacturers?
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
Smurf
Post by Smurf »
Roenut wrote:Just bent mine too (kzn130)
Nah can't recall whether it was a certain model or year..
Ask Toyota about the bushes and see if they can give you a year or model number?
truckingood
tweake wrote:is the arm actually bending or just flexing on the bushes?
the arm itself is bending about 10mm back from drag link joint, so with the truck on the ground(so under load) if you grab the FL and move it as if you were steering it(truck not running) you can see the arm bending up and down no movement in bushes I put a brand new one on to see if that would fix it but made it worse due to the are only being 15mm thick, old one is 20mm
front suspension goes ome shocks, terrain tamer 26mm torsion bars, 1'' ball joint spacers and terrain tamer hd steering dampner
Return to “Toyota”
